Old 01-18-2014, 08:58 PM   #1
aotte1
Re: 1986 Chevy C10 SWB Step Side
Removing the bed. I tried the 8 bolts and they all turned. Removed one by drilling the head with 1/2 drill ( it should have been a little bigger). Then 1/4 ed the head with a die grinder and cut off wheel. Next the head was removed with a chisel in 1/4s, just light tap removed each quarter of the head. Then the bolt was driven out through the bottom. It took a lot to drive it out the bottom several blows. Picture of tools used is shown below. For the next one will get a larger diameter drill, so that I will do less quartering with die grinder and cut off wheel. The drilling went very easy with a high quality drill( higher cutting angle so that it cuts easier). Pictures of the parts that make up the assembly also included.
aotte1 is offline   Reply With Quote
Old 01-18-2014, 09:00 PM   #2
aotte1
Bolt assembly
Old 01-18-2014, 09:06 PM   #3
aotte1
The above picture shows the bolt, two quarters of the bolt head ( the other two quarters of the head are on the ground somewhere), the washer that is under the bolt head with a square hole, below the washer is a round cylinder that rests between the washer and the frame cross piece.
Old 01-18-2014, 09:08 PM   #4
aotte1
Frame area where cylinder rests.
Old 01-18-2014, 09:11 PM   #5
aotte1
Larger picture of frame area, all the wet looking area is the drilling oil, used lots of it to protect drill.
Old 01-18-2014, 09:13 PM   #6
aotte1
Upside down pics, need to get better w/ I Pad camera!!!
Old 01-18-2014, 09:18 PM   #7
aotte1
Picture of the rear mount for the bed, short bed step side.
Old 01-24-2014, 06:15 PM   #8
jpnh
jpnh's Avatar
Originally Posted by aotte1 View Post
Bolt assembly
save those spacers/offset washers to reuse,and buy 1/2 inch carriage bolts {got mine at lowes} dont buy the bolts from LMC their cheesey.-jeff
jpnh is offline   Reply With Quote
Old 01-24-2014, 06:36 PM   #9
walkerb
walkerb's Avatar
Hahaha i have a set of those bolts in my garage! Very scary
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 01-24-2014, 09:35 PM   #10
aotte1
Jeff, thanks for the advice. Today I got five more bed mounting bolts out for a total of 6 of the 8. I got a larger drill, 5/8 for an inventory of 1/4, 3/8, 1/2, and 5/8. I now drill each starting with the smallest about 3/8 to 1/2 below the bottom of the head. The new 5/8 drill makes removing the head easier. But still use the cut off wheel to quarter cut the head as close to the washer below as possible. Then chisel and 2.5 lb hammer to remove heads, followed by punch and hammer to drive out remaining bolt. I had to hammer pretty hard to drive the remaining bolt out.
Findings today are the bed mounting bolts were yellow cad plated. The washer under the bed mounting bolt was painted red on all of the surface. Therefor the washer were in place when bed was painted?? ( NOTE:This is Canadian built truck)
Les
Old 01-25-2014, 07:28 PM   #11
jpnh
jpnh's Avatar
yeah it sux. how they get ya is they put m in with the bed hardware kit so you need most of the bolts no sense returning them i bet theres a few people with these kickin around the thinner bolt/offset washer is way smaller in diameter/no spacers/not long enough clearly out of touch with reality or a good scam.ill end up using them on something.
Old 01-25-2014, 08:29 PM   #12
jpnh
jpnh's Avatar
when i did my bed after i unbolted it i flipped it over onto a couple broken office chairs with plywood and some other wood i had kickin around bolted/screwed to them i usually inherit the broken computer chairs when the backs break off made a nice cradle i could roll it around easy i flipped it over to get at all the nuts on the bottom that hold the wood in the wood was still in mine when i got it after tryn to get them off a couple came loose then i broke a few off then i sawzalled a couple and found it was easier to just break m all off i used a breaker bar/socket with no wood in there you might be able to do something different if their just spinning on ya then i stripped all the paint and rust off the bottom with a wire brush wheel on a drill before flipping it back over to do the top had to do this a few times when u get the wood kit the holes arent drilled in it so your gonna have to pre fit the wood and figure exactally where you need the holes cant be off at all no room for error gotta make sure the wood is far enough under the sides that are spotwelded to the bed you dont have to take them off but you have to make sure the wood lines up with the hold downs in the grooves if your not far enough under the side the or not square it makes a difference the hold downs wont line up in the grooves gotta get all the wood in there straight with the hold down strips in the grooves and the gap between the wood and the rear panel at the end of the bed consistant then you use a sharpie to mark all the holes to be drilled then take them back out to drill em need to do all the fitting/ drilling before ya finish the wood.if i can think of anything else ill try n let ya know.
Old 01-26-2014, 12:21 AM   #13
aotte1
Jeff, thanks for your detailed description of how you did it. It will be very useful in planning what I need to do. This is turning into a bigger project then I thought it would be with all the bolts and more bolts!
Today got the last of the bed mounting bolts removed, that one bolt is really long. Going to remove the gas tank tomorrow for safety reasons since I will be replacing my cab corners also. Got the four bolts at the rear of the tank loose tonight. Tomorrow plan to drain the gas out and finish removing it since I can have my side entrance door open to help remove any fumes. My garage is spray foam insulated, totally air tight so have to be extra carefully about explosive fumes! It will be 45 degrees tomorrow then back down to really cold again, so my chance to have the door open.
Will probably have a few questions if that is ok. Your bed is looking really nice, epoxy primer. So you fit your new bed wood before painting, good idea with all the turning of bed needed, did not think of that. What wood are you using, northern white pine? Great wood if you can get it. I special ordered it for the trim on my garage, if cared for last forever.
Thanks,
Les
