68 C 10
![]() Join Date: Aug 2010
Porterbuilt trailing arms
I have a set of the PB 3 inch drop TArms the u bolts had two nuts (one locking nut) and a washer on them how do you get both nuts on the u bolt. and what type of wrench are you using to tithen up the nut a standard 1 1/16 will not fit without grinding down. PB must be off today for the Holiday
Any suggestions would to get this buttoned up today.
Kevin "Life is Hard But its Harder when your Stupid" John Wayne 68 C10 70 C20 http://67-72chevytrucks.com/vboard/s....php?t=602326# |
#2 | |
Re: Porterbuilt trailing arms
![]() The plain steel nuts are just for mock-up and will not be used for final assembly. We use a 1 1/16 wrench to tighten them up. You may want to mock it up with the plain steel nuts, as it might be necessary to trim some of the u-bolt so you have enough room to use the box end of the wrench and slide it out afterwards. We modified one a little to work more easily. Took a grinder to the open end so it fit in better and gave us more range of motion. Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
![]() Join Date: Jan 2012
I wrestled mine for awhile then took Nate's advise and trimmed some of the U bolt and it was cake after that.
Thanks again Nate for a great product. |
