Old 01-20-2014, 12:29 AM   #1
rs74
rs74's Avatar
Door panel question
Are all K5 door panels the same as the trucks? Same design and all. I know the burbs have the different cloth inserts and as far as I know that is the only difference other than driver side having the four window switch. I am going to be looking for the lighter gray interior that the burb and blazers have and need a set of power door panels from a blazer. Just want to make sure I have my facts straight before I go looking and calling.
Seems like the bucket seat design switched sometime. I am thinking 86-88 were one style and 89-91 were another?
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 01-20-2014, 10:26 AM   #2
Jonboy
Slots go on anything!
Re: Door panel question
Correct on both counts. The buckets are the same even further back, but the upper changed (along with the padding and fabric) in '89. The later seats have a more squared headrest area.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 01-21-2014, 12:02 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
my 87 burb had power locks manual windows ,
gives me the panel without the big 4 hole switch
I was able to use the newer door pulls on the older doors
except for the 87 drivers door panel,i think the rest is 89 vent/door glass
not sure on the seats but yes there is a change and some only have one arm rest
I used 89s they have two,drilled a few holes,bolted up
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
