Old 01-13-2014, 02:15 PM   #1
K10Scottsdale78
K10Scottsdale78's Avatar
Towing capacity
Whats the towing capacity for a 78 k10 with a 400 sbc? Just curious
-1978 K10 Scottsdale LWB
400 SBC 4 spd muncie SM465 ("heavy chevy")
-2002 Toyota Celica GT
5spd (gas saving daily driver)
-1969 Pontiac Firebird (post-college project car)
K10Scottsdale78 is offline   Reply With Quote
Old 01-13-2014, 03:15 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Towing capacity
Depends on the axle ratio:
3.07 = 8500 GCW
3.40 = 9500 GCW
3.73 = 10500 GCW (Gross Combined Weight).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-15-2014, 06:38 PM   #3
K10Scottsdale78
Re: Towing capacity
no clue what my gear ratio is, all ive been told is that its the original one from 78. Is there a way to tell from looking at the diff case?
Old 01-16-2014, 08:37 AM   #4
Keith Seymore
Re: Towing capacity
Only if you know all the axle part number broadcast codes. Do you still have the SPID label? It should show an axle ratio option code (GQ1-base, or HE4, GT4).
Easiest is to jack it up and spin the wheels and count how many times the driveshaft goes around.
Most exact is to pull the rear diff cover and count teeth. Probably needs the fluid changed anyway and this would be a good time to do it.
K
1979-1986
1986 - 2019
Old 01-22-2014, 09:41 AM   #5
K10Scottsdale78
Re: Towing capacity
ill probably do that in the spring, both my diffs look like theyre leaking a little bit so I want to change the the gaskets before another season of driving, especially with the chance of me getting a job in colorado for the summer, and needing to drive over 1500 miles out there
Old 01-22-2014, 01:34 PM   #6
xole
xole's Avatar
Re: Towing capacity
Pulling and stopping are two very different things. I would make sure you have a trailer with brakes and a brake controller.
-D
'86 Chevy K10 SWB Custom Deluxe 4x4
'94 Chevy Corvette
'07 Ford Mustang
'08 Lexus LS 460
xole is offline   Reply With Quote
