Old 01-22-2014, 10:36 PM   #1
70shortstep
Registerd User
70shortstep's Avatar
70 Short Stepside
I have started my frame off build. First a little background on my love for these trucks. When I was 14 (1978), my brother in law's (Joe) dad (Frog) had a 68 short step, dark green, 3ott. I used to go with them and haul hay and work around their place. I remember getting to pull the trailer around the field to load the hay. My sister and Joe moved to Texarkana. My dad and I carried a load of things to them in Frog's truck. Dad let me drive down and back. One year dad, Joe, Frog and I took the truck to Little Rock to the tractor show. We were so cramped that Joe had to shift while Frog was driving. I told Frog if he ever got rid of the truck, I wanted it. Well 25 years passes and the old truck is pretty well beaten to death. Frog forgot about my love for the truck and lets someone have it just to get rid of it. When I found out it was gone I was sick and Frog was so upset that he had forgotten that I wanted it. I started looking for a truck and after about a year I found my truck on ebay. I wanted a 6 cyl, 3ott, stepside, base truck. I bought my truck in 2006. My daughter and I hauled a trailer to Virginia and brought it back. My dad passed away in 2007, and Frog died in 2008. Joe was killed in a tractor accident in 2011. Like a lot of you guys, driving this old truck around takes me back to a simpler time.
I have not done much to it except put the shifter back on the column and a little maintenance. I actually started this the first of November. I went out to cut the steel plate out of the bed and put the wood back. Well one thing leads to another as you will see.
70shortstep is offline   Reply With Quote
Old 01-22-2014, 10:58 PM   #2
70shortstep
Registerd User
Re: 70 Short Stepside
Old 01-22-2014, 10:59 PM   #3
70shortstep
Registerd User
Old 01-22-2014, 11:03 PM   #4
70shortstep
Registerd User
Old 01-22-2014, 11:05 PM   #5
70shortstep
Registerd User
I thought well I am this far in, I should take the bed off.
Old 01-22-2014, 11:11 PM   #6
70shortstep
Registerd User
That went pretty well so what the heck, pull the front clip
Old 01-22-2014, 11:14 PM   #7
70shortstep
Registerd User
Old 01-22-2014, 11:17 PM   #8
70shortstep
Registerd User
Old 01-22-2014, 11:19 PM   #9
70shortstep
Registerd User
Old 01-22-2014, 11:25 PM   #10
70shortstep
Registerd User
I decided to put front disc on. I found a front end out of an 83. My crossmember was toast anyway.
Old 01-22-2014, 11:29 PM   #11
70shortstep
Registerd User
Taking part to get blasted and powder coat .
Parts powder coated
Old 01-22-2014, 11:31 PM   #12
70shortstep
Registerd User
Starting assembly
Old 01-22-2014, 11:34 PM   #13
flashed
WOW ,that was a nice truck to start with ,cant wait to see what happens next.
flashed is offline   Reply With Quote
Old 01-22-2014, 11:36 PM   #14
70shortstep
Registerd User
Front end. Replaced all steering linkage and ball joints. All new brake components
Old 01-22-2014, 11:43 PM   #15
70shortstep
Registerd User
Replaced axles with 72 5 lug. All new drum brake components. New axle seals.
Going with rallye wheels
Old 01-22-2014, 11:46 PM   #16
70shortstep
Registerd User
I want to stay with the 250. The truck only has 86000 miles on it. Engine runs fine but rebuilt it anyway.
Old 01-22-2014, 11:54 PM   #17
70shortstep
Registerd User
Engine on frame
Old 01-23-2014, 12:11 AM   #18
70shortstep
Registerd User
Added power steering. What a pain in the butt trying to work out the pulleys. I think I have it worked out. I am waiting on a ps pulley that I hope will finish it up.
Old 01-23-2014, 08:59 AM   #19
70shortstep
Registerd User
I have the normal rust issues in the usual places. Cab corners, rockers, cab supports etc. cutting off the excess rust before taking it to be blasted on Friday. Thanks to my friend Danny for his help and his plasma cutter.
Old 01-23-2014, 09:03 AM   #20
70shortstep
Registerd User
Old 01-23-2014, 07:27 PM   #21
70shortstep
Registerd User
More rust
Old 01-23-2014, 07:28 PM   #22
70shortstep
Registerd User
Dropped cab off for blasting
Old 01-23-2014, 08:25 PM   #23
flashed
WOW ,never dreamed there would be that much rust from the first picture you posted but it hides pretty good. I got lucky with mine as it wasnt that bad just rockers and minor spots in the cab corners and one mount. Your build is going a lot faster than mine did ,mine has been almost 3 years and hopefully done soon. I look forward to seeing you finish yours .
Old 01-23-2014, 08:57 PM   #24
gdavis
gdavis's Avatar
yea you got some cancer there. But it's nothing that can't be fixed. and a lot of sweat.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 01-23-2014, 09:39 PM   #25
Kennuck
Kennuck's Avatar
I'm in the middle of a 70 short step build myself. Subscribed.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
