Closed Thread
Old 01-20-2014, 09:26 PM   #1
TJ's Chevy
TJ's Chevy's Avatar
What did you do to your truck today part II.
The first one was shut down do to server errors....so I thought I'd start a new one. Here we go! I'll start....Took mine fer a lovely cruise down my country road...and had some fun in the fields towing a trailer....
TJ's Chevy is offline
Old 01-20-2014, 09:51 PM   #2
NEWFISHER
NEWFISHER's Avatar
Re: What did you do to your truck today part II.
Was feeling "horny" after work , so within the theme of my cow hide seat, I installed a Bull Horn.
and hid the button
GOD BLESS AMERICA!
NEWFISHER is offline
Old 01-20-2014, 11:42 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I added a link to this thread at the end of the original thread, to help redirect people to the new one.
Thanks for starting this one up.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline
Old 01-20-2014, 11:50 PM   #4
Slow Build
Slow Build's Avatar
Link to the old thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=368988
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline
Old 01-21-2014, 02:43 AM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
The truck was getting hot on the freeway so I figured the radiator was plugging up. I had an extra so I thought I would swap it out. I was right about the clogged radiator, when I opened the drain plug it dripped out. I drove the truck today and the temp barely rose. I will know better when I take it on a longer ride on the freeway..
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 01-21-2014, 04:03 AM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
and hid the button
Years ago I had one of the old metal ones with the cable pull on the side. That thing was so much fun. I could get cows to come up the fence and follow the car! I guess it must have sounded pretty convincing.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 01-21-2014, 08:48 AM   #7
jbgroby
jbgroby's Avatar
Installed the OEM Hazard Switch.
jbgroby is offline
Old 01-21-2014, 09:04 AM   #8
Clyde65
Clyde65's Avatar
and hid the button
Sorry Newfisher, I was thinking you meant this...
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline
Old 01-21-2014, 12:06 PM   #9
TJ's Chevy
TJ's Chevy's Avatar
Hey NEWFISHER, we need a video of what the horn sounds like!
Old 01-21-2014, 12:57 PM   #10
forestb
forestb's Avatar
Just adding myself to this thread.
forestb is offline
Old 01-21-2014, 01:54 PM   #11
65Gregg
65Gregg's Avatar
I had to replace my dimmer switch after Bigfoot(my son) got his size 13's caught in the harness and destroyed it when he pulled to untangle his fat foot. I figured by the time he turned 30 he would be over being clumsy and rambunctious, wrong.....
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline
Old 01-21-2014, 03:11 PM   #12
Mater/10
Mater/10's Avatar
Today im pondering painting my Rallys the body color after school. primered and all!
1964 Chevorlet Custom 10 350/350 ,ps,mb,A/c,BBW -Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=608625
1969 Chevy Nova 2 dr I6 250/powerglide
1967,68,69,70,71,72 Chevy Frankenstein
Mater/10 is offline
Old 01-21-2014, 04:05 PM   #13
TJ's Chevy
TJ's Chevy's Avatar
Sorry..but....ppphhhHAHAHAHAHAHHAAH!!!! AN HEY!!! I am waaaaay younger then 30 an I am in a 13 shoe!!!!! HEEHEEHEE!!!! Am glad you were able to fix it.
Old 01-21-2014, 07:04 PM   #14
speedy_steve
I pulled the carburetor off and attempted to remove the intake manifold. Was rewarded by popping the head off a bolt and copious amounts of fuel all over the garage. This truck has a way of installing perma-grin on my face and is a great way to kill a lunch break.
speedy_steve is offline
Old 01-21-2014, 07:37 PM   #15
Sharps40
I might be closein in on fixin all the oil leaks I've had in a new engine and trans install. Rear main on the engine and speedo bullet on the trans. But it was a good evenin layin under the truck wipein oil off previously clean surfaces, squoochin it down with cleaner and wipein it again. Onna these days its gonna be oil tight cause I won't have done stupid stuff like accidentally pluggin the breather port with a spanky new baffled grommet causing all the oil to push past the spanky new rear main seal.....dayum, thassa lotta work for putting in the wrong grommet in the first place.
Sharps40 is offline
Old 01-21-2014, 09:11 PM   #16
TJ's Chevy
TJ's Chevy's Avatar
That truck done been actin like a f$%d! You hidin somethin from us!?!?!?!?!
Old 01-21-2014, 10:50 PM   #17
TJ's Chevy
TJ's Chevy's Avatar
Got some goodies in the mail today!!!!
Old 01-22-2014, 04:49 PM   #18
Moax
Moax's Avatar
Actually had some free time so my son and I
removed the in-cab gas tank and installed a new
under bed one. Nice little father son (10 yrs)
project.
Eddie
A lonely DODGERS fan in a sea of orange and black
1963 GMC Project
1997 Silverado 4X4
Moax is offline
Old 01-22-2014, 06:27 PM   #19
crossland1962
crossland1962's Avatar
Moax what is that tank from?
crossland1962 is offline
Old 01-22-2014, 06:29 PM   #20
Sharps40
Stared at the underside of my truck after three times to make sure the oil leak was fixed. Still dry!
Sharps40 is offline
Old 01-22-2014, 06:53 PM   #21
Moax
Moax's Avatar
CROSSLAND1962, I bought the tank from Tanks Inc.
It's a 16 gal. universal tank. Great price $215 plus tax/shipping.
Eddie
1963 GMC Project
1997 Silverado 4X4
Moax is offline
Old 01-23-2014, 12:33 AM   #22
Vernski
Hay T.J. what color or colors of have you choose for your truck when you paint it? I changed my oil and added some of the zinc in mine today...Vernski
Vernski is offline
Old 01-23-2014, 04:28 PM   #23
TJ's Chevy
TJ's Chevy's Avatar
Hey Vernski,
I am planning on a blue an silver two tone(like my projects name "Two Tone" lol). Anyhow, Frame will be gloss black. I am not exactly sure yet...Still thinking. lol. But that is what the game plan is so far.
Old 01-23-2014, 07:29 PM   #24
Chevy Fleetside
I was looking at that tank. Would love to come by and see how it works if that is ok.. I can bring my son with me also. He is 11.
Old 01-25-2014, 10:17 AM   #25
firemanjimtfd
firemanjimtfd's Avatar
Picked up a 350 horse 350 to go in my short wide today.
firemanjimtfd is offline
Closed Thread
