01-22-2014, 11:46 PM | #1 |
rear coils the same for 60-62 &63-72?
Hey guys!
I've been looking into getting new rear coil springs for my '62 1/2ton longbed and I've seen listings saying some fit 60-72 and others say 60-62 only. I'm planning on lowering with coils but even listings for stock coils say one or the other. Is there actually a difference?? |
01-22-2014, 11:58 PM | #2 |
Re: rear coils the same for 60-62 &63-72?
The earlier springs have equal spacing between the coils, later ones have a progressive spacing. A section of closer spaced coils is built into them for added performance under load, while the section with wider spacing helps to soften the ride when running light.
01-23-2014, 12:08 AM | #3 |
Thanks AcampoDave!
So other than the spring rate, they'll interchange? |
01-23-2014, 01:21 AM | #4 |
I'm pretty sure they will. Can anyone else out there back that up?
