Old 12-31-2013, 03:37 AM   #101
ZouchaR
Re: My 63 Project
Put my new springs in today. This is the frame before.
ZouchaR is offline   Reply With Quote
Old 12-31-2013, 03:38 AM   #102
ZouchaR
Re: My 63 Project
And mocking up the new springs. Supposed to be four inch drop springs.
Old 12-31-2013, 03:43 AM   #103
ZouchaR
Re: My 63 Project
And now the frame... After the install. Does my math not add up???
Old 12-31-2013, 12:38 PM   #104
chevyrestoguy
chevyrestoguy's Avatar
Re: My 63 Project
To get an accurate measurement, you're going to need to have the bed installed and be at close to your final weight on the rear suspension. I think you're going to be OK.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 12-31-2013, 09:01 PM   #105
ZouchaR
Re: My 63 Project
I am pretty happy with the look... and we shall see what the final looks like after we get the bed and some real tires and wheels.... I was worried about going too far with 4"....
Old 12-31-2013, 11:19 PM   #106
ZouchaR
Re: My 63 Project
Shaving some bumper bolt heads. Two down, four to go.
Old 01-01-2014, 08:39 PM   #107
ZouchaR
Re: My 63 Project
Getting pretty good with this "rattle can" primer!!!
Old 01-01-2014, 08:40 PM   #108
ZouchaR
Re: My 63 Project
And the dash.
Old 01-22-2014, 08:36 PM   #109
ZouchaR
Re: My 63 Project
Spent some time today working on my door panels.
Old 01-22-2014, 08:37 PM   #110
ZouchaR
Re: My 63 Project
Notice that one of them has holes for the arm rest. That has to go.
Old 01-22-2014, 08:38 PM   #111
ZouchaR
Re: My 63 Project
Little bit of welding.
Old 01-22-2014, 08:40 PM   #112
ZouchaR
Re: My 63 Project
Little bit of grinding.
Old 01-22-2014, 08:41 PM   #113
ZouchaR
Re: My 63 Project
Little bit of filler.
Old 01-22-2014, 08:42 PM   #114
ZouchaR
Re: My 63 Project
Little more sanding, ready for primer and paint!
Old 01-22-2014, 09:51 PM   #115
ZouchaR
Re: My 63 Project
And with a couple coats of paint.
Old 01-22-2014, 09:53 PM   #116
ZouchaR
Re: My 63 Project
Ok, so now I need some help.
How do I get the gas tank mounts out?? Obviously there are two bolts that come up from the bottom, but it looks like the mounts are spot welded to the rear of the cab.
Old 01-23-2014, 11:57 AM   #117
McMurphy
McMurphy's Avatar
Re: My 63 Project
I think they are spot welded to the floor as well... IIRC 66Farmer did the cleanest removal of those that I have seen on this site.
If you dont already have a spot weld cutter, you may want to get one.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 01-23-2014, 12:52 PM   #118
Ta2Don
Ta2Don's Avatar
Re: My 63 Project
Just found your build...
Great start, I'm in for the ride...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 01-23-2014, 08:57 PM   #119
ZouchaR
Re: My 63 Project
Thin layer of filler on the fender.
Old 01-23-2014, 08:58 PM   #120
ZouchaR
Re: My 63 Project
Workin on the door.
Old 01-23-2014, 08:59 PM   #121
ZouchaR
Re: My 63 Project
About four hours with that air file in my hands is about all I can take. It will wear you out!!
Old 01-23-2014, 09:20 PM   #122
ZouchaR
Re: My 63 Project
I picked one up today Murph. I will post pics as I take them out.
Old 01-24-2014, 12:36 PM   #123
TJ's Chevy
TJ's Chevy's Avatar
Re: My 63 Project
Nice work! Yer doing great!
Old 01-24-2014, 03:26 PM   #124
McMurphy
McMurphy's Avatar
Re: My 63 Project
If you never used one before, here are a couple of tips:
A light hammer and a sharp punch will usually give you enough of a indent for the weld cutter to ride in until you get a good circular channel started.
But not always, so keep another drill handy with a bit in it that is just a tad larger than the spindle on the weld cutter. This will give your weld cutter the stability over uneven spots to get the job done.
On the back of the cab be very cautious when cutting else you will be plugging holes you didnt need to (I tried using an air chisel and learned the very hard way).
Remember the spot weld cutter is sharp, and fast, if you are not paying 100% attention you will cut dime size holes clean through both layers of steel. In my tiral and error learning I found that it was better to under cut it, and tap tap tap with a chisel between the two welded pieces, than it was to cut all the way thru.
I hope this helps you (hopefully you read this before you get hands on the project) and good luck !!
Here is the build I was looking for, a great fellow doing an awesome build:
http://67-72chevytrucks.com/vboard/s...=513377&page=6
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 01-24-2014, 08:10 PM   #125
ZouchaR
Re: My 63 Project
Great advice Murph... and if I had actually read your reply before I started.. then we would have been thinking exactly the same way.... See the following Pics....
