Spindle / Tie Rod Question
73-87 Spindles (I have the CPP Mods)
What is the diameter of the Tie Rod hole? Is it tapered? If so, what is the degree of taper? Thanks guys.....
Tim Baillie Installer/Designer/Fabricator Trick Factory Customs Company - www.trickfactory.com Personal - www.hzemall.com Instagram - @hzemall |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Spindle / Tie Rod Question
Sorry,... I can't help on the taper size of the spindle hole.
It is definitely tapered. What year truck are you working on? I would swap tie rods or spindles to get the correct fit,... before I would ream the tie rod hole in the spindle.
Mine is a 79
![]() Join Date: Mar 2012
The modular spindles take a 73-87 tie rod and ball joints.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
I know that, that isn't what I was asking but thanks.
http://67-72chevytrucks.com/vboard/s...d.php?t=447061
http://67-72chevytrucks.com/gallery/...4016_large.jpg Is this the information your are looking for? This guy used 1.5" per foot (7degree) in his build to retain the stock tie rod ends. Last edited by Suburban_Tyler; 01-25-2014 at 07:30 AM. |
