Old 01-26-2014, 11:05 AM   #1
survivingalone
87 chevy 1/2 ton 4x4 frame the same as a 2wd frame
i need the last two rear cross members for my friends 87 chevy 4x4 frame. are the 2wd frames the same as the 4wd? i listed this in the parts section also. i just need to know if i find cross members from a 2wd frame will they work on a 4wd frame? if anyone has the last two cross members i will pay shipping to Pa and let me know the price of the parts. need asap. thank you.
survivingalone is offline   Reply With Quote
Old 01-26-2014, 11:19 AM   #2
makman1297
makman1297's Avatar
Re: 87 chevy 1/2 ton 4x4 frame the same as a 2wd frame
They are similar, I used the cross member support from a 4wd to replace the rusted out one on my 2wd frame, it fit just fine. I think its the same one you are talking about. Just half to grind off the rivets and use bolts.
1981 Dodge D-150 (under construction)
2007 Chevy Suburban
2010 Dodge Charger R/T
1980 Kawasaki KZ 440
2004 Harley Sportster 1200
makman1297 is offline   Reply With Quote
Old 01-26-2014, 02:09 PM   #3
survivingalone
thank you. anyone have the last two rear frame cross members?
Old 01-27-2014, 12:58 PM   #4
survivingalone
anyone have an older frame they can help me out with the cross members?
