Old member
Plug them. The one coming from the tank is for purging the tank so the cab doesn't fill up with gas fumes. You can take the canister completely out and leave the line under the truck.
The canister was full of Charcoil to purge the cab out from gas fumes and smog controlls for the engine in 71. Original GM fuel vapor charcoal canister used to help cut down or eliminate fuel vapors. Essential part of the fuel and emissions system ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
