Old 01-20-2014, 09:57 PM   #1
Iceburgh
Iceburgh's Avatar
Exhaust sensor
How far away from the engine does this have to be......looking at shorty headers for clearance but not sure if the bung can go in there or should I look for long tubs that will fit.....not sure they are out there
Iceburgh is offline   Reply With Quote
Old 01-21-2014, 12:57 AM   #2
mcfarlnd
Re: Exhaust sensor
If you are talking about o2 sensors, I recommend just down stream of the collector regardless of long tube or shorties. I have long tubes that have them mounted in the aft primary tubes on each bank and the ECM don't like it. When I log on hp tuners, they aren't a smooth switching pattern like when I have them after the collector.
mcfarlnd is offline   Reply With Quote
Old 01-21-2014, 12:12 PM   #3
Hart_Rod
Hart_Rod's Avatar
Re: Exhaust sensor
+1
Hart_Rod is offline   Reply With Quote
Old 01-22-2014, 03:01 AM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: Exhaust sensor
Headers on my 6.0. I don't think it matters on the distance on a heated senor. The older ones that weren't heated I think it did though.
[IMG][/IMG]
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-22-2014, 05:32 AM   #5
ls1nova71
ls1nova71's Avatar
Re: Exhaust sensor
Generally the closer to the engine the better, and between the 9 o'clock and 3 o'clock position so that condensation doesn't sit in them.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-26-2014, 07:44 PM   #6
crazy longhorn
Fabricate till you "puke"
Re: Exhaust sensor
20" , from the head pipe to sensor, is what I got today on the the hotrod shows? That sounds about right, as looking at the stock setup....Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-26-2014, 10:08 PM   #7
Iceburgh
Iceburgh's Avatar
Re: Exhaust sensor
Thanks for the info
Old 01-27-2014, 03:24 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Exhaust sensor
20" is a ballpark, but it works. Usually the idea is to have it a far "up" as you can, while still being in the collector so ALL the exhaust can mix before/while passing the sensor. This is for "normal" manifolds that bolt to a "mid" pipe, or on full length headers at the collector.
Mounting it too close to the exhaust ports (like on a short header setup), will put an extra amount of heat load (direct and indirect) on the sensors. The sensor can burn out faster and is more prone to erratic/false readings, and I wouldn't be surprised if the difference in exhaust pulse very close to the heads had an effect as well.
Too far away and you have the exhaust cooling down, as well as an increased likely hood that a clean air leak can occur before the sensor throwing off readings.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
