01-25-2014, 03:12 PM | #1 |
No Run, No Fuel?
Went over to a friend's house the other day to pick up some milking equipment. As I came up to the the last hill before the house, the engine surged, cut out, then came back and ran fine. I made it to my friend's, loaded up the equipment, and made it 50 yards before the engine cut out again for good.
I was thinking the fuel filter might be plugged, but bypassing it makes no difference. The motor just plain isn't getting fuel. There's no fuel coming past the fuel pump. I guess the question is, is this symptomatic of a bad fuel pump? Or something further back in the fuel system?
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy" 1996 Gmc 1500 Z71, 350, 4l60e, 3.73s 1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s 1989 Toyota Pickup 22re, auto, 3.73 |
01-26-2014, 11:23 AM | #2 |
Re: No Run, No Fuel?
Just remove the large fuel hose from the tank and hook a longer piece of hose to it and suck on it to see if gas is available. If you can't suck it, the fuel pump can't suck it either. I did this a couple weeks ago and got gas but the fuel pump wouldn't suck it. Found out the short 6 inch hose from the metal line to the pump had a pin hole in it that didn't leak any fuel but was sucking air.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
01-28-2014, 08:29 AM | #3 |
Hmm, thanks for the suggestion. I'll look into that today and let you know.
01-28-2014, 11:39 AM | #4 |
Next!
You could also have a clogged fuel tank sock. If it looks like this you'll have those symptoms.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
01-28-2014, 02:29 PM | #5 |
Depending on which truck you are working on there will be different answers. Gas truck may have water in fuel. Diesel may go the same way but also fuel may have gelled on you as cold as it has been. Only ever had on gel on me. It was the folks vehicle they had it hauled to the dealership. New filter and a bit of time in the warm shop took care of it.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
