Hollywood
backspacing on 88-2000's rcsb
Hi, just wondering if anyone out there that has a bagged 88-2000 c-1500 knows if my backspacing is correct for some rims I just ordered.
I ordered 20 x 8.5" AR rims with 5 1/4" backspacing on a stock style front end that is bagged and laying rail? BTW, this is for the front end only, I have 20 x 10's in the back
1968 cSSt shortbed 1971 custom deluxe shortbed frame off 1991 caddilac escalade ST shortbed 1992 chevy ext. cab Project: leftovers 2003 Silverado ext. cab shortbed (my dad's truck R.I.P.) 1969 trans am clone, pro tour 1985 Yamaha Vmax, custom 1993 Yamaha Vmax, showbike 1969 Sears Suburban SS12 lawn tractor |
#2 | |
Re: backspacing on 88-2000's rcsb
Your listed size has an additional 1/2" of wheel width & 1/4" less back-spacing which on my truck would be scrubbing the front fender lip. My concern w/my numbers was what the inside of the wheel might rub as I don't have an easy way to check w/o purchasing a wheel/BS tool.
Hollywood
Thanks Scoti, I appreciate the help. While in another forumn about this same issue I found someone that was running a 20 x 8.5 wheel with 5 1/4" backspace and he said it would tuck up into the fender but....if he was having custom wheels made he would add at least 1/4", which I did. I am going with the 5.5" backspace and I think everything will be ok. Your story kinda backs it up and I appreciate it.
I am a little late to the party here, but I think you will be right where you need to be with the 5.5" BS. We would normally run a 5.25 on a static truck, and that extra .25" for bagged trucks running a similar suspension setup you have.
Sounds like a nice truck! I really like that body style. |
#5 | |
Usually on a 4/6 drop, but I tend to like wheels a little closer to the outer fender.
I don't like them 'lost' inside of a wheel-well but there needs to be a decent amount of clearance to avoid buzzing. At 4/6 drop, the 8.5" w/5.25" BS would prob be fine.
Frequent Flyer
20x8.5 with 5.25 bs
20x8.5 with 5.75 bs |
Hollywood
Kool, thanks guys. You input is greatly appreciated. Those are some awesome trucks, I especially like the light blue one since I am a Tarheel!
