![]() Join Date: Oct 2006
1977 3/4T gvw?
Does 7100lbs GVW sound right for a 1977 3/4T 2wd? It has a 350/4spd. If I remember right, my "Spirit of 76" (heavy half) had a GVW of 7200! How would a 1/2t have a heavier GVW than a 3/4t?
Is there a difference in frame for the heavier 3/4t?(7500/8400?) or is it all spring/brake packaging? Thanks
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
Re: 1977 3/4T gvw?
maybe the 1/2t was 6200lb?
Another Day, Another Dollar
Re: 1977 3/4T gvw?
Heavy halves were built under sketchy circumstances to bypass emission regulations. Don't worry too much about that. You will find camper specials are 8400 gvw and I think they had a little more in the rear leaf department. Might have also had an extra set of bolts holding the bed down.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() |
Re: 1977 3/4T gvw?
Re: 1977 3/4T gvw?
Rear axle ratio also factors into GVW. My '79 3/4 ton has a 7100 GVW even with 9 leaf springs on the rear and 10 ply tires. Structurally it's a HD 3/4 ton but with a rear axle ratio of 3.73, the GVW is lower.
#6 | ||
Re: 1977 3/4T gvw?
![]() Quote:
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#7 | |
Re: 1977 3/4T gvw?
Attached below is the GVW selector chart from the info packet for the '77 Chevy pickup, courtesy of the GM Heritage Center archive - K
#8 | |
Re: 1977 3/4T gvw?
K http://www.gmheritagecenter.com/docs...olet-Truck.pdf
Re: 1977 3/4T gvw?
Read through that last night. It appears the only differences in the GVW on 3/4t's is spring,tires and brake packages. I plan on putting hydroboost and 10 ply tires on my newly acquired 77 C20.
Thanks again guys! and Thank You Keith once again for that info!
