Old 01-29-2014, 10:25 AM   #1
rs74
rs74's Avatar
Body mount shims?
I bought a body mount kit for my short bed and they came with square (shims)? Is tha exactly what they are is shims? I didn't take any off mine when I disassembled it. I just assume that I use them in case I need to square everything up. Is that correct.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 01-29-2014, 10:30 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Body mount shims?
Square shim with square hole in the middle ?
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-29-2014, 10:36 AM   #3
rs74
rs74's Avatar
Round hole.
Roy
1987 R10 shortie
Old 01-29-2014, 10:43 AM   #4
Tx Firefighter
They look like the ones that are used under the bolt heads of the core support mounts. They go down inside the well on top of the core support, then you drop the bolt through them. It spreads the load from the bolt to keep from crushing the sheetmetal core support.
Old 01-29-2014, 10:45 AM   #5
rs74
rs74's Avatar
Not sure as there are four of them and they come in the set for the cab. The cab, bed, and core support hardware all came in their own boxes. Sorry I should have been a bit more specific. I had cab mount in my head and didn't say that.
Roy
1987 R10 shortie
Old 01-29-2014, 10:49 AM   #6
Tx Firefighter
Looking again at your picture, if that's a cab emblem for size reference, those are some big shims and definitely not the core support washers. They'd be like half that size.
I'll step back and see what others offer up so maybe I can learn something here.
Old 01-29-2014, 10:54 AM   #7
rs74
rs74's Avatar
Yeah they are 2 3/4" shims.
Roy
1987 R10 shortie
Old 01-29-2014, 12:44 PM   #8
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
they look like they go between the cab n mount prolly a height thing
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-29-2014, 12:48 PM   #9
rs74
rs74's Avatar
I just put the cab mounts on the other day and left these off. I am going to wait until I get the bed liner sprayed in and fenders put on before I tighten the cab mounts all the way down and then I guess I will see if they are needed. That way I can see how all the body lines match up. Anybody have a pic of their untouched cab mounts to see if they are in there.
Roy
1987 R10 shortie
Old 01-29-2014, 01:09 PM   #10
J Knight
J Knight's Avatar
When you put the cab, front clip, and bed on the frame with new bushings you can use these shims on top of the bushings or for the bed on top of the frame to line up the body. Its just an option if you need it. Ive had to do it on a truck before to match up the body lines. If you bed lines up fine you dont need them.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 01-29-2014, 05:18 PM   #11
dieseldawg142
dieseldawg142's Avatar
took my untouched mounts out the other yr, the spacer goes on top of the mount against the body
http://67-72chevytrucks.com/vboard/a...9&d=1362991886
dieseldawg142 is offline   Reply With Quote
Old 01-29-2014, 05:41 PM   #12
bdiamond
The truck I got a few donor cups from had them between the driver side front cab mount and floor. My blazer had a bottom washer between the cab and upper mount as a shim. Not sure why, it seems to line up without it. Anyone seen that?
bdiamond is offline   Reply With Quote
