Old 01-30-2014, 03:18 PM   #1
TonyJohnson
TonyJohnson's Avatar
Re: parasitic battery drain
Jump a 12 volt light between the neg batt pole and the neg bat cable. It will light up. Pull fuses until you find the bad circuit (the light will go out) and then backtrack...
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 01-30-2014, 05:37 PM   #2
etindoll
Do you still have the external voltage regulator? If so it could be that mine went bad and would drain the battery. I swapped to an internally regulated alternator.
etindoll is offline   Reply With Quote
