Old 01-31-2014, 03:22 PM   #21
USArmyCombatMedic
Re: speedo question
Personally, I would check to make sure that the speedo cable is all the way on. If so, I would disconnect and lube the end of the cable. It is suppose to be pretty well lubed which thinking back to when I did mine, I forgot to lube the new cable which could explain my problem. Also, when you say jump all over the place, I assuming you mean it bounces as in your going 25MPH the needle will bounce from 15ish to 35ish? Or like random jumps from 5MPH to 85MPH to 30MPH?
USArmyCombatMedic is offline   Reply With Quote
