Old 01-31-2014, 01:10 PM   #1
upon1
upon1's Avatar
Simple ls wiring questions
I'm putting a 5.3/4l60e in my '54 and can't get a hold of the guy that built my harness. I'm using a haywire chassis harness and a universal ignition switch. And a lokar shifter
Couple questions:
I have a wire labeled neutral safety, I don't have any connectors for the factory gear indicator on the drivers side of the trans. Where does this go?
Do I need to hook the brake switch wire up to get it running?
Thanks in advance.
"Lifes to short to drive an ugly truck."
Project 55 To Life
http://67-72chevytrucks.com/vboard/s...d.php?t=432994
upon1 is offline   Reply With Quote
Old 01-31-2014, 03:01 PM   #2
mooseknuckles
mooseknuckles's Avatar
Re: Simple ls wiring questions
It will run without those hooked up....if you're using a lokar gear indicator you can wire the neutral safety into that...the brake switch wire gets spliced into a wire on the brake switch...I did have a pic saved....
mooseknuckles is offline   Reply With Quote
Old 01-31-2014, 04:12 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The gear indicator can be left unused if you want, I removed that whole section of trans harness.
I would hook up the brake wire before starting though, unless your JUST going to do a stationary start. I don't like the vehicle moving or using any trans functions without the brake switch input (plus the TAC will want the TCC functions hooked up if its dbw)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-31-2014, 04:27 PM   #4
solidaxel
solidaxel's Avatar
Good to know about the TCC and the TAC, first time I heard that one.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-31-2014, 06:27 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Well one of the wires was labeled TAC, so I kinda figured it was important lol
Old 01-31-2014, 07:11 PM   #6
upon1
upon1's Avatar
It is the DBW. Will it run without it connected? I don't have a lokar gear indicator, just the nss on the shifter
Project 55 To Life
Old 01-31-2014, 09:42 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Yes it will run, but you may run into some issues with the trans or the dbw control without it connected. The tcc will refuse to lock/unlock without a reference from the switch. I'm not 100% WHAT the Tac looks for, but considering how sensitive DBW can be, I wouldn't be surprised if it wanted to see it connected.
Just to start and idle its not a requirement.
You do need VATS etc turned off at the pcm either way.
