Old 02-20-2013, 10:24 PM   #1
68 Longbed Dan
Removing my dash...help lol
So I've pulled out all the bolts I can find, it moves a bit but it just won't let go. I don't think just hauling on it is a good idea until I found out what's holding it lol hence my question here. My goal was to take it out to make the body work a bit easier.
thanks!
Dan
1968 Longbed Stepside C10
68 Longbed Dan is offline   Reply With Quote
Old 02-20-2013, 10:43 PM   #2
SS Tim
SS Tim's Avatar
Re: Removing my dash...help lol
If you are refering to the metal dash panel #6 here, it is welded to the body at the windshield with a lot of spot welds.
SS Tim is offline   Reply With Quote
Old 02-20-2013, 11:03 PM   #3
68 Longbed Dan
Ha! there is my problem its awfully deceiving that they put bolts lol what gives!
Dan
Old 02-20-2013, 11:17 PM   #4
ole dollor
ole dollor's Avatar
are you talking about the dash pad or the complete dash?
ole dollor is offline   Reply With Quote
Old 02-20-2013, 11:23 PM   #5
SS Tim
SS Tim's Avatar
During cab assembly the bolts are used to position the instrument panel then it is spot welded along the windshield lip. The assembly manual can give some more detail.
Old 02-20-2013, 11:40 PM   #6
HeloCrewChief
HeloCrewChief's Avatar
I've heard of guys cutting along the dash pad line that is hidden and welding it back in there. Not too sure on that though.
1970 C10 to K20 conversion
1974 GMC Jimmy
1968 50th Anniversary Short Bed
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
HeloCrewChief is offline   Reply With Quote
Old 02-21-2013, 01:25 AM   #7
68 Longbed Dan
I didn't see any rust along side the dash. so I'll probably put the bolts back in and pretend I wasn't trying to take it off lol
Dan
Old 02-21-2013, 04:23 AM   #8
BrutonLS1
BrutonLS1's Avatar
Where can I get this assembly manual?
-Bruton
1968 GMC long bed 5.7/700R4
--I'd rather push a Chevy, than drive a Ford.--
BrutonLS1 is offline   Reply With Quote
Old 02-21-2013, 05:13 AM   #9
LakeAnna
LakeAnna's Avatar
Sounds like a good plan, I know that's what I did... It is a pita when you have the cab masked and trying to lay paint in there though. Spray a while... let the fog clear... spray some more... watch it run! I don't know about yours but mine was dirty but no issues with rust except over by the antenna mast area. After sucking a lot of dust it's all good now.
Chris
72 RESTO
http://67-72chevytrucks.com/vboard/s...d.php?t=501870
LakeAnna is offline   Reply With Quote
Old 02-21-2013, 06:09 AM   #10
SS Tim
SS Tim's Avatar
Just about anyone who sells Chevrolet truck parts will have a 67-72 factory assembly manual. Might even be able to find it on CD. Be forewarned it is not paginated and a pita to find anything in at first. However it has a lot of information for people willing to use it.
Here is the page specifying the 34 spotwelds for the instrument panel.
Old 02-21-2013, 10:02 AM   #11
WIDESIDE72
WIDESIDE72's Avatar
IMO you don't want to take the steel dash out unless absolutely necessary. real pita. Classic parts sells the assembly manuals at a good price to begin with ($30), then there is a 10% discount if you use "stovebolt" promo code. When I started my current build, I thought about buying one but have parted several, restored one GMC, so I know how itgoes together after all.
WIDESIDE72 is offline   Reply With Quote
Old 02-21-2013, 12:55 PM   #12
ChevyCruizer
17's too small
ChevyCruizer's Avatar
i have pulled a couple of "uncut" AC dashes from the junk yard. drilled out all of the spot welds with a cordless and then the 3 bolts on each side. It isnt that hard.
You might be suprised how much surface rust is between the dash and cab once you remove it. Someone on here has pictures. For a daily driver dont bother but if you are gonna restore it 100% then I would say yes pull it out.
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 02-21-2013, 01:52 PM   #13
dirish
dirish's Avatar
Got mine off ebay.
dirish is offline   Reply With Quote
Old 02-01-2014, 09:11 PM   #14
54belair
54belair's Avatar
You dont want to remove the steel dash----unless you Have to! I did it in my build and its not quick or real easy. I would not recommend drilling out the pinch welds (personally I wouldnt do anythng to possibly upset the way the windshield fits.)
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
