Windy Corner of a Dirty Street
Re: A/C When Pulling The Motor
If it wasn’t for the fact you want to install the firewall thing and have to open the lines anyway I would say just tie the compressor up somewhere and not even bother cracking the lines then leave the rest of the accessories on the engine. I typically always pull engines with accessories still bolted to them, especially light engines like small blocks or a V6, but I tie up the A/C compressor under the hood and never crack a line. Being you are going to open the lines anyway, just let her rip and let the refrigerant go and don’t tell anybody, like in a public forum
![]() It is irresponsible for a place of business to use such a practice but think about all of the auto accidents that happen every day where condensers are smashed open while releasing refrigerant into the atmosphere. If loosing refrigerant into the atmosphere was such a huge catastrophe you would think the feds would require auto manufacturers to engineering a method of making a leak and crash proof A/C systems. Maybe all of the loose R134A floating around the atmosphere is why here are no more unicorns. I dunno…. Of course, in the Republic of Kalifornia you can’t even fart without a catalytic converter in your Fruit of a Looms. Better not let your neighbor hear the A/C line hissing once you crack it open Never cracked a line on this Suburban. Subs with rear A/C hold A LOT of refrigerant and I didn’t want to waste any ![]() ![]() PS.....I would not recommend pulling the trans and engine together. That is a great way to loose a lot of ATF on your driveway causing more catastrophe to the environment and pulling the radiator support is a huge waste of time but that is just me. Pull the engine over the rad support then it will take you about 10 minutes to drop the trans down by itself. That is my method.....Cleaner that way.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
#2 | |
RAT1968 '68 Cab/'71 Parts
I guess the main reason I wanted to leave the trans connected is how much easier it is to take it apart after they are pulled out together; and, to get the "click-click-click" correctly lined up, and then bolted up, while the trans and "new" engine are sitting separately on blocks on the floor of the garage before they go back in. I think there's a strong possibility my previously "new", and now leaking, rear main was caused by stabbing the trans in when the trans and engine were trying to mate from underneath one of the two times I had the trans out for leaks before I drove ten feet. Or, maybe the time we pulled the motor separately from the trans (a couple of days later) to change out those freeze plugs... ...even with two guys down there and both of us being very careful. So, you'd say the best drill is to loosen the trans/engine where they mate to the back of the block....Is that *after* draining the trans, dropping the tranny cross member, unbolting the torque converter from the flex plate, and pulling the driveshaft?......Then cherry-picking the engine by itself (obviously after disconnecting everything, including the motor mount bolts) ? Doesn't that create some possible "hanging" up that might be rough on that rear main seal?...And the same on the way back in? Probably a (some) stupid question(s).....Ones I thought I would completely avoid by pulling the engine and trans together...And I think that works room-wise with the trans attached without pulling the radiator, (electric) fans, core support, and misc A/C components (dryer, lines, and condenser). That is, if I pull the accessories and serp brackets and goodies. I guess I'm just afraid of going at the tranny in a Fred Flinstone gorilla method and breaking or scoring seals..or something...coming out. Or, even worse, when it's going back in. And, thanks for the advice on the 134a......I thought it might be made of rose-pedal scent or something non-ozone killing. I'll take proper action. ![]() ![]() ![]()
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 02-02-2014 at 01:36 AM. |
#3 | |
![]() The new stuff R134A is supposed to be less harmful to the environment yet at the same time they (gov) tightens up the regulations for proper disposal and tax the crap out of R12 So you cant afford it. Same deal with residential/commercial (buildings) R410A, R407C vs R22 same but different... Really there are probably thousands of different refrigerants. If you vent it... on the subject of oil, well the oil is carried by the freon so if you cut a line you lose oil, if you create a tiny leak the oil stays, mostly. The collision guys have specific recharge amounts for oil based on crash damage. the more important part (at least what they tell you in commercial) is to plug all components once freon is removed. This is because the oil is (probably going to butcher the word) hydroscopic: "absorbs moisture". Why do you care? your PAG oil absorbing moisture can coagulate and clog (turn to fatty mush) the system and fail to lubricate. So what ever you do put some rubber plugs, plastic cap plugs etc in the hose ends, compressor fittings etc. It is much easier to drain an automotive AC compressor than try to flip a Copeland Scroll compressor over to drain and replace the POE oil.... But I can say I have used a used Automotive compressor that was stored open and drained and replaced the oil without issue.. The deal with evac'ing the system (using a vacuum pump) is to suck down the atmosphere to remove atmospheric moisture and better accept the freon charge. Yet I have charged a vehicle without a vacuum pump and it worked great. I guess it can depend on your climate (humidity). When working on an open system whether brazing or screw on fittings we use a nitrogen purge (dry air nitrogen) to displace oxygen for oxidization (copper oxide dust inside) and nitrogen displaces atmospheric air (think moisture/humidity). Sorry for the lesson and I may not be 100% accurate due to fluid ingestion and BTW I was born in Kalifornia, no hard feelings although pelosi could fall off a cliff...
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
