Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-20-2014, 12:41 AM   #1
studda
studda's Avatar
DIY Blasting Cabinet
Go ahead, make fun of it if you like but hey, it was EXTREMELY cheap to make. I bought a plastic tote, cut two holes in the side of it and taped bread bags in the holes so sand wouldn't come out and wear gloves so it doesn't sting my hands. I cut a hole in the lid and taped a piece of Plexiglas over it so I could see in. I cut a hole in the side to run the air hoses and voila, I have a blasting cabinet. I just dump the sand back into the sand hopper when it starts getting low (I use pool filter sand because 50lbs for $5). I know it doesn't look pretty but it does its job of keeping sand off my garage floor and out of my face. I had everything laying around so the only expense was the cost of the tote, which was less than $10. I need to get a bigger tote so I can blast bigger parts. I got sloppy with the cutting and cut one hole low and one high
studda is offline   Reply With Quote
Old 01-20-2014, 01:58 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: DIY Blasting Cabinet
I think that's a great idea!
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 02-02-2014, 12:02 AM   #3
maxxxy
maxxxy's Avatar
I did the same thing with an old enclosed crate, probably 1.5'x1.5'x4' inner dimensions (barely big enough to stick my crossmember in. stuck a piece of plexi in the top and cut out holes for some elbow length gloves i had lying around. I also put put some screen door material around a light bulb to protect it from projectile sand, and stuck it in there.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 02-02-2014, 12:17 AM   #4
kaycee
kaycee's Avatar
Cool I'm making one out of a 55 gal barell I picked up from work need to get me a light for it I'll try and get some pics.Good job on your part as long as it does its job thats what counts.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 02-02-2014, 04:11 PM   #5
studda
studda's Avatar
I thought about making one out of an old refrigerator. Or at least a bigger tote. The current setup is kind of awkward with a part that is relatively long.
Old 02-03-2014, 02:49 PM   #6
SeniorVerde
SeniorVerde's Avatar
I'm thinking of the 55 gal. drum myself; when they're sitting sideways, all the sand collects in the low spot. can't decide on the door though.
Post those shots, Kaycee!
SeniorVerde is offline   Reply With Quote
Old 02-03-2014, 08:31 PM   #7
kaycee
kaycee's Avatar
OK here you go need to get some gloves and should be good to go I cut the 1 end out except for a 6" piece at the bottom ,so I could mount 3/4" plywood on and have the hinges stable,allso bought a coupla 2"soffit vents to install for fresh air.If you dont have these and hook up a shop vac it will create a vacum inside the drum. On the big bung hole (LOL) I put a PVC fitting to hook up shop vac to help keep the dust clear.Not done yet but thats the plan
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 02-03-2014, 08:33 PM   #8
kaycee
kaycee's Avatar
Hers the other end
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 02-03-2014, 09:58 PM   #9
studda
studda's Avatar
That thing looks awesome Kaycee. The shop vac is a great idea too. The dust in mine is terrible and I have to take the lid off every now and then to clear it out just to see. Maybe I'll make one out of a barrel like yours. Are you going to put a grate in there or just hold the part with one hand and blast with the other?
Old 02-03-2014, 10:27 PM   #10
kaycee
kaycee's Avatar
Thanks ,Yep going to put a grate of some sort in there ,I got the soffit vents for a coupla bucks at Home Depot.I built the stand out of some old crap we had laying around so the drum is not attached to it and you can tilt to your liking.So if you want to stand or sit on a stool you can adjust the barell to that posistion.I siliconed every seam on it and took a piece of vacum tubing and slit it down 1 side to slip over the edge of metal that was left over from removing the end to seal the door.
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 02-03-2014, 11:13 PM   #11
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Originally Posted by studda View Post
...I use pool filter sand ...
Studda, PLEASE read your sand bags and make sure it is NOT silica sand (most pool filtering sand is silica sand).
DO NOT USE SILICA SAND FOR SAND BLASTING as it is a serious carcinogen plus the cause of silicosis.
http://en.wikipedia.org/wiki/Silicosis
Old 02-03-2014, 11:26 PM   #12
Hardesty454
Hardesty454's Avatar
That barrel blaster is AWESOME. Cant believe I never thought of that...
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 02-04-2014, 09:56 AM   #13
studda
studda's Avatar
Good to know. I don't recall exactly what kind it is as I threw the bag away. I'll change it out though just to be on the safe side. Good looking out.
Old 02-10-2014, 12:29 AM   #14
68anthony
68anthony's Avatar
Great idea using a drum for a blast cabinet. I might have to use this for my shop.
68anthony is offline   Reply With Quote
Old 02-10-2014, 06:05 PM   #15
maxxxy
maxxxy's Avatar
That barrel is a great idea! How do you retrieve the sand to reuse it?
Max
Max's bagged 81
Old 02-10-2014, 07:55 PM   #16
kaycee
kaycee's Avatar
Used it to blast a little fender bracket the other day ,works like a champ still in the mock up stage but couldn't wait .I am going to make a hopper to catch the media,and weld it to the bottom of barrel.Going to try and make the hopper like a regular blast cabinet,may even make it out of wood.I just have the pickup tube laying in the bottom for now ,this way it will hold about 5" of media on the bottom.Need to get it so a guy can re- screen the media and make it last(I'm a cheap bast#$).Should be able to work on it this week some more,I got some metal road signs from work I'll try and fab something up when the boss isn't looking.Got the gloves and a little floresent light to put in it this weekend. I have about $45 into it now
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 02-19-2014, 12:20 AM   #17
studda
studda's Avatar
That's a heck of a blast cabinet for $45. You're putting my $10 cheepo to shame. My brother works at a chemical plant. I'll have him get me a free 55 gallon drum and do likewise.
