01-31-2014, 08:43 AM | #1 |
Plugging fuel filler hole
I will be doing an LS swap soon on my 72 C10 so obviously the factory tank is going to be taken out. I'm trying to avoid paint or bodywork to fill in the hole left behind where the filler neck passed through. What I had envisioned is using a rubber type "plug" or blank off that attaches like a firewall grommet. I was curious if anyone knows the diameter of the hole that is left in the cab once one removes the filler neck and factory grommet?
I had also considered welding in a "dummy" filler neck so I could put on the stock gas cap and give the appearance of a stock truck from the outside. Has anyone ever done this? Stupid idea? |
01-31-2014, 09:46 AM | #2 |
Re: Plugging fuel filler hole
I had also considered welding in a "dummy" filler neck so I could put on the stock gas cap and give the appearance of a stock truck from the outside. Has anyone ever done this? Stupid idea? [/QUOTE]
I like this idea, if you are going to stay with the stock look. If not weld in a plate and try to match the paint.
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
01-31-2014, 09:56 AM | #3 | |
Yeah that was my initial concern about the bodywork...not so much the labor of doing the bodywork, but the ability to match the paint and make it look good. |
01-31-2014, 11:15 AM | #4 |
You could slice off the original filler neck from the old tank ( Take it out, fill to the top with water, and very carefully cut it off with a hack saw, so there's no chance of it going boom), then leave it sticking out of the rubber grommet with a cap on it. It would look stock. I would plug it up with something, however, to prevent somebody from accidentally filling the cab up with gas.
"Negative people always seem to have a problem for every solution" |
01-31-2014, 11:42 AM | #5 |
Check out the Holley truck. It's a 67 short bed and it's running a LS motor and they left the stock gas cap in place. May have to google it. Nice truck.
Thanks, Casey 71 Chevy C-10 SWB 350/400 PS, PB The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
01-31-2014, 01:55 PM | #6 |
the boat guy
You CAN use the stock tank when doing an ls swap...
Or leave the tank in, or cut the front of the tank out so you have the storage.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
01-31-2014, 05:55 PM | #7 |
I probably should have said I'm doing a GM or Aeromotive in tank fuel pump module. And as far as I know, there's no way to make that work in a stock tank. With an inline pump, yes, I agree.
On another note, I recall reading where the rubber filler neck donut grommet specific to the 1972 models was still available new from GM. Anyone know the part number or where to get them? |
01-31-2014, 06:42 PM | #8 | |
01-31-2014, 08:19 PM | #9 | |
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
02-01-2014, 01:18 AM | #10 | |
02-01-2014, 06:15 AM | #11 |
Old member
Long ago before I welded the hole up in my 71 I left the rubber grommlet in place and bought a cheap plastic gas cap drilled a couple of holes on the inside of the cap and tie wrapped it to the inside of the cab. I pulled it really tight and never had any leaking when washing it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-01-2014, 06:31 AM | #12 |
you could fill the hole with a rubber chicken head
02-01-2014, 10:38 AM | #13 |
02-03-2014, 12:40 AM | #14 | |
Sam |
