Old 02-02-2014, 07:24 PM   #1
Steve Cole
Gauge paint? - not the needles!
I noticed the markings on the instrument gauges are a light greenish color, has anyone found a paint that was real close to the original color? I am going to install a later model clock but the numbers and markings are white, I though it would look more factory if the markings were the greenish color the other gauges are. I'm not sure how I would do this but I thought I would see if the correct paint was available first. Any thoughts on how to re-color the markings?
Steve Cole is offline   Reply With Quote
Old 02-02-2014, 09:36 PM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Gauge paint? - not the needles!
I've had success making an acrylic paint mix into a light wash , just don't add to much water. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 02-02-2014, 11:40 PM   #3
FirstOwner69
FirstOwner69's Avatar
I don't think you will ever notice a difference once installed. I haven't. Also, most original gauges have faded significantly.
FirstOwner69 is offline   Reply With Quote
Old 02-03-2014, 01:10 AM   #4
67_C-30
I have a radical idea!
67_C-30's Avatar
I mixed a few drops of green paint in clear coat several years ago to and sprayed the entire gauge face on one of that dashes that had a 70's Camaro tach installed in the center, and it turned out pretty good. I experimented by dropping one drop of green in the clear at a time and spraying it on something white until I got a pretty good match. The green tilt was so subtle that it only affected the white markings and you couldn't see it on the black face of the guage once installed.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 02-03-2014, 01:11 AM   #5
67_C-30
67_C-30's Avatar
BTW- I did tape up the orange needle, because the green tilt would have probably showed up on it.
My trucks
Old 02-03-2014, 09:48 AM   #6
Steve Cole
That is very interesting! I would never have thought of that. Do you remember what color of green you used?
