Old 02-03-2014, 09:19 PM   #4
Shooters_7
Re: Wire Harness Routing...
Which hole in the fire wall did you run the "rear" harness down and where did you get the rubber grommets from? Too many wires with the updated harness to go down the door sill like the stock one did.... I put convoluted tubing around the harness so it wouldn't rub and cut into the wiring but would like to find a grommet to use with this. I ordered new factory ones for the engine and headlight harness's as the old ones fell apart during removal.
Conner
1965 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=535078
Shooters_7 is offline   Reply With Quote
