Old 01-27-2014, 09:08 AM   #1
DT1
DT1's Avatar
Return Spring for Brake Pedal Broke
I jumped in the truck the other day and when I depressed the brake I heard a "Ping" and felt the pedal drop about a half inch. I got out to take a look and spotted a U shaped piece of spring metal in the floor mat. Upon further inspection, I could see way up under the column a heavy spring just kind of dangling there. I got the flashlight and an inspection mirror, but try as I might, I couldn't see where it is suppose to attach to the pedal. I consulted my manual but found no clear information about it. It looks like I'm going to have to remove the gauge cluster to even get to it.
Has anyone here recently replaced this spring? If so, a few pointers on how to gain easy access would be greatly appreciated. I hate to start ripping into something and then finding out that there was a simpler way to go about it.
DT1 is offline   Reply With Quote
Old 01-27-2014, 09:13 AM   #2
Bigdav160
Bigdav160's Avatar
Re: Return Spring for Brake Pedal Broke
I don't remember any spring on the brake pedal.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-27-2014, 12:06 PM   #3
DT1
DT1's Avatar
I didn't think it had one either but there it was. Plain as day.
Old 01-27-2014, 12:30 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
One end of it fastens in a bracket right by the brake light switch and the other end fastens up by the firewall.
LockDoc
Leon
Old 01-27-2014, 12:36 PM   #5
1972SUPERSB
1972SUPERSB's Avatar
I just replaced this spring last week. What a pain! It is a very strong spring and I took off the plate under steering column and lowered the steering column a little to get to it. Very tough to get to. Maybe taking off the instrument cluster would be easeir. Not sure. Let me know what you figure out.
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 01-27-2014, 02:20 PM   #6
DT1
DT1's Avatar
I was able to see the bracket by the firewall but I can't see where the other end attaches. Does it actually attach somewhere high on the pedal itself?
Old 01-27-2014, 02:36 PM   #7
1972SUPERSB
It attaches close to the brake light switch. I had to take the switch out to make it easier. I also had to take off the push rod to the brake booster as well
Jeff
Old 01-27-2014, 03:01 PM   #8
jim ellis
jim ellis's Avatar
to replace your over center spring disconnect push rod from pedal push pedal back down on floor remove pedal stop.pull pedal up as far as needed to hook up spring then reinstall stop and push rod.
jim ellis is offline   Reply With Quote
Old 01-27-2014, 03:18 PM   #9
DT1
DT1's Avatar
Thanks,
I'll give it a try.
Old 02-04-2014, 09:26 AM   #10
DT1
DT1's Avatar
That, my friends, was one of the hardest things I have ever done to my truck.
I followed the advice I got from jim ellis but it wasn't quite that simple. I dropped the steering column as far as it would go, disconnected the pedal rod and removed the switch. The brake pedal wouldn't go down far enough to to allow the spring to connect to the back bracket because the stop light switch bracket was in the way and I still had to stretch the spring at least an inch. It's a very hard spring to stretch, especially since I couldn't get my hand up in there to grab it. I finally had to make a tool out of a piece of 1/4 inch rod that was 18 inches long. I notched the rod to catch the end of the spring. Then I contorted my 6' 3" body between the seat and firewall and pushed the rod (More than a few times) until it finally caught the back bracket. I hope the new spring is robust enough because I really don't want to ever do it again.
