Old 02-04-2014, 03:13 AM   #1
chevymadness
Front axle on 2wd
Hi guys! I should start by saying I know this is kind of stupid and feel free to laugh but hey they laughed at Loui's Armstrong and look at him now.Anyway I have this 82 silverado and it has strong sentimental value and money put into it .But I have a problem it's. 2wd :/ and as many more guys these days doing crazy fabrication to there trucks.Well I would like to take care of this 2wd problem because you see 2wds cannot be lifted.The front end of course has no axle or leaf springs and has only coil springs etc.So after comming across this 4x4 forum I found some thread where a guy had a 4x2 and just tore off the front end and welded on the leaf spring mounts to mount the leaf springs and then mount the axle exactly like you would a 4x4.The front.He also did this for cheap and I would imagine you can preety much use any axle because the axle is not really going to be working.Im just wondering about the issues with steering colum or what type of issues can be the hardest to achieve and what do you guys think.I want a 6 inch lift.Essentially the truck is going to have a 4x4 front end identical but none working.Less expensive for full working 4x4 drive train and a less hassle.I only plan to tow with this rig but want a 6 inch lift!
1982 chevy silverado
It's all about original guys original let me say again original.
chevymadness is offline   Reply With Quote
Old 02-04-2014, 03:37 AM   #2
willett
Another Day, Another Dollar
willett's Avatar
Re: Front axle on 2wd
Find a rusty 4x 3/4 or 1 ton and swap your truck over! You will end up with better axles and you can probably nab one for cheap
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 02-04-2014, 03:37 AM   #3
willett
willett's Avatar
And I'm pretty sure you can buy 2wd lifts
Old 02-04-2014, 11:56 AM   #4
Wrecked1982
Wrecked1982's Avatar
if you want a 4wd the easiest way is to find a 4x4 frame and swap your body onto it.
if you want to keep it as original as possible find a 4x4 frame and swap springs brackets,crossmembers, etc...
http://www.hillbillywizard.com/images/frame.jpg
thats a 1 ton tough
Wrecked1982 is offline   Reply With Quote
Old 02-04-2014, 01:31 PM   #5
chevymadness
Oh lord if I had a nickle for every John who has told me to swap or there "preety" sure a lift kit is out there for a 82 4x2 silverado.I would definetly have a 10,000 lift under the truck.Down here its texas not the south these trucks specially in the border cost nothing short of 1g on a good day.All I need is a axle is spend a couple hundred at best I just need advice on the steering column ,steering etc.What would need to be fabricated.What is exactly different.
Old 02-04-2014, 01:34 PM   #6
chevymadness
I could buy a 10 bolt for 100$ at the junk yard I heard down here.I cannot swap its to much and if I eer do I would fabricate it myself and I have no place to work on the tuck or he money.And labor down here will kill me.
Old 02-04-2014, 01:46 PM   #7
chevymadness
thats a 1 ton tough
Ah thank you I was going to ask we're I can find some 4x4 frame photos.
Old 02-04-2014, 02:00 PM   #8
BONUSCAB
If the truck truly does hold a large amount of sentimental value, leave it alone. Go buy a 4x4, they are a dime a dozen.
Few things in life will make you look stupider than putting a dollar sign after a number.
BONUSCAB is offline   Reply With Quote
Old 02-04-2014, 07:04 PM   #9
LONGHAIR
It can be done, but it would take some fabrication skills. If you are capable of doing some cutting and welding, it shouldn't be that bad, but.....the steering might need a bit of attention. True 4x4 steering move the pitman arm front to back to move the steering side to side. You could probably use the 4x2 steering box to get a crossover type steering....again, fab skills.
This is something that a guy and his buddies would have to workout on their own, it would not be cost-effective to have to pay someone else to do it.
Also, probably not the best idea for your daily driver, it might be down for a while as you work this out.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-04-2014, 08:39 PM   #10
willett
willett's Avatar
But How will your truck be all about original if you stuff a front diff under it?
Old 02-04-2014, 11:42 PM   #11
andrewmp6
What your talking about is basicly a 4x4 swap with out the t case.You will have to change out the engine cross member and whole front suspension and steering depending on lift and if you want high steer or not.Fabtech use to make a 2wd lift kit and one of our vendors has one he was thinking about copying it and selling them http://67-72chevytrucks.com/vboard/s...d.php?t=612963 The other option is to use 88-98 2wd lift spindles they work with a little change like a ball joint.Those spindles are 4 inch lift and if you run a 1 ton coil spring it will get you close to 6 inches lift total.
Old 02-05-2014, 03:05 AM   #12
chevymadness
Heck yea now your talking you gave some good thaughts here.I will look into these spindles and what truck should these spindles come off.Do you think I would need to change anything else other then the spindles and coil springs.How about steering.
Old 02-05-2014, 03:07 AM   #13
chevymadness
Welp..you got me there haha
Old 02-05-2014, 04:36 AM   #14
INSIDIOUS '86
INSIDIOUS '86's Avatar
Man I'm taking my k5 and getting rid of all the 4x4 stuff. You can have it free if you pay shipping. Given the mods allow this?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 02-05-2014, 04:38 AM   #15
INSIDIOUS '86
All the leaf spring mounts crossmembers and such will just get scrapped here
Old 02-05-2014, 08:45 AM   #16
andrewmp6
I found the post it took me a while http://67-72chevytrucks.com/vboard/s...d.php?t=509417
Old 02-05-2014, 02:34 PM   #17
willett
willett's Avatar
Hey what ratio is in that thing?
Old 02-06-2014, 03:05 AM   #18
chevymadness
Hey thanks that was some really interesting material on that thread.It seems you can lift any truck with some good spindles but in conclusion he reached a 4 to 5 inch lift tops.The a arms are getting in the way at that point.And from my judgment I think a front axle placement is best to go it will more or less cost the same and can have any lift.I want a 6 inch lift!
