Old 02-04-2014, 10:09 PM   #201
ChickenCityHotRods
ChickenCityHotRods's Avatar
Re: Twin Turbo and Dropmember equipped, Jeremy's '65
Just saw a picture of your S10 in the new Goodguys Gazette!
Patiently waiting on my copy! A buddy sent me a few pics via text last night.
Twin Turbo and Dropmember equipped http://67-72chevytrucks.com/vboard/s...d.php?t=586662
Follow us on Instagram @CHICKENCITYHOTRODS
ChickenCityHotRods is offline   Reply With Quote
Old 02-10-2014, 08:49 AM   #202
shortbed70
shortbed70's Avatar
Have fun with the cab supports... Ones I bought fit like a horse saddle on a hog! Watch the outer rocker too, had some fitment issues on the last truck I did.. Looking good man keep it up!
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 02-13-2014, 10:21 PM   #203
ChickenCityHotRods
Thanks.
Old 02-13-2014, 11:10 PM   #204
markeb01
Senior Enthusiast
markeb01's Avatar
Simply artwork. Love the frame design and construction quality!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 02-15-2014, 09:24 PM   #205
ChickenCityHotRods
Talking Re: Twin Turbo and Dropmember equipped, Jeremy's '65
Thanks!
Old 02-15-2014, 10:42 PM   #206
ChickenCityHotRods
Time to start putting all the new panels on. I thought I'd go a little in more in depth showing how I fit and install some of the patch panels. Before I went full time at my own shop I was the shop manager/ lead tech at the AMD Installation Center (previously known as the Goodmark Installation Center.) Although our focus there was mainly GM and Chrysler muscle cars, the knowledge and skills I developed working with aftermarket sheet metal lends itself to these trucks we all love too. Hopefully I can pass on some tips to help everyone rid their own trucks of rust.
I rough trimmed the floor patch/inner rocker and clamped it in place to mark for final trimming. If you notice in the last pic in a previous post I left the cab supports in place even though they will be replaced. They give a good reference to start mocking the new pieces to.
With the floor clamped in place we find our first fitment issue. This is the edge at the back of the floor that welds to the cab corner/ backwall. The patch also didn't cover all the area that needed to be replaced due to rust.
The sharpie line is parallel with the edge as is, the scribe line is referenced off the backwall were the panel needs to be.
I chose to make a new flange instead of cutting and welding in a pie shaped wedge to move the edge to the proper location. I also added more to the top to complete the patch.
Much better fit now.
The other issue with the floor is with the flange that meets the firewall. You can see it's slopes down but should be straight. This will receive a similar fix as the rear flange but will take place when repairing the toe board/firewall.
Old 02-16-2014, 12:26 AM   #207
lowlifej
lowlifej's Avatar
that's why you make the big bucks chris!
lowlifej is offline   Reply With Quote
Old 03-30-2014, 01:00 AM   #208
kvn1011
Kvn1011
kvn1011's Avatar
Nice work! subscribed !
kvn1011 is offline   Reply With Quote
Old 03-30-2014, 11:39 AM   #209
TJ's Chevy
TJ's Chevy's Avatar
Nice work on the patch panels!
Old 03-30-2014, 02:16 PM   #210
clemdaddy
clemdaddy's Avatar
blown away... this is one top notch build.
clemdaddy is offline   Reply With Quote
Old 03-30-2014, 02:24 PM   #211
superflysteiny
superflysteiny's Avatar
More nice work
superflysteiny is offline   Reply With Quote
Old 03-30-2014, 08:33 PM   #212
Painter D
Painter D's Avatar
Awesome build
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 03-31-2014, 03:22 AM   #213
Vernski
I like what I've seen so far, Welcome I'm subscribed thanks very nice work way above average you got the touch...Vernski
Vernski is offline   Reply With Quote
Old 03-31-2014, 11:06 AM   #214
Kyle@FTP
Everything is better with twins! The Watts link also turned out really nice. Put a 10.5 radial on the back and you have a low 10s high 9s truck. Or leave the ruber band tires and to killer burn outs.
Kyle@FTP is offline   Reply With Quote
Old 03-31-2014, 09:52 PM   #215
j.walters
j.walters's Avatar
Killer looking build !!! Nothing says nasty like a twined LS motor.
1964 swb bbw body drop on 22s ls swapped c10 build..
http://67-72chevytrucks.com/vboard/s...d.php?t=617623
j.walters is offline   Reply With Quote
Old 04-27-2014, 09:59 PM   #216
ChickenCityHotRods
Next on the list to replace is the kick panel. It fit pretty good without any modification.
After the kick panel it's time for the lower A post patch. This area has lots of surfaces to line up. After positioning the panel and trying to line up the different surfaces this was the best fit I could achieve.
A relief cut down the edge is all it took to line everything up.
A few minutes with the welder and grinder and the post is done.
Old 04-27-2014, 10:37 PM   #217
idreama300
Amazing work! Thanks for the patch panel tips.
idreama300 is offline   Reply With Quote
Old 09-21-2014, 11:05 PM   #218
lowlifej
lowlifej's Avatar
Well we have decided a name for this build finally and Chris will be posting some pics soon we have a lot to catch up on!!!! "Must Be Nice" is her name for all the people that love throwing those three words around being a smart a$$ lol
Old 09-22-2014, 06:02 AM   #219
jjzepplin
jjzepplin's Avatar
Must Be Nice! I had to do it.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-22-2014, 09:50 AM   #220
67cheby
67cheby
67cheby's Avatar
Dig it !
67cheby is offline   Reply With Quote
Old 09-22-2014, 10:49 PM   #221
lowlifej
lowlifej's Avatar
I knew someone would lol
Old 09-22-2014, 11:39 PM   #222
Average Joe
Average Joe's Avatar
WOW!!! Amazing build!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 09-23-2014, 11:55 PM   #223
Thunderwagen
This is an amazing build!
1990 GMC Sierra
http://67-72chevytrucks.com/vboard/s...d.php?t=617587
Thunderwagen is offline   Reply With Quote
Old 11-24-2014, 08:17 PM   #224
Sickfast1964
Any updates??
What an amazing build !!
Sickfast1964 is offline   Reply With Quote
Old 02-02-2015, 01:13 AM   #225
lowlifej
lowlifej's Avatar
Been a while since we have updated the Must Be Nice build so im going to try to get us caught up starting with some nice hand made parts from Metal Worx Inc
chicken city hot rods, driveway werks, dropmember, raceline, twin turbo
