Old 02-05-2014, 02:13 PM   #24
jtrichard
Re: Headlight Switch
tom you would be better off with about 30 amp max remember just like in your house wiring not everything is on at the same time the main power is 12ga. and only good to 40amp MAX at 10' and that is only for short periods .......look at this for your wire and fuse size http://www.offroaders.com/tech/12-vo...gauge-amps.htm
jtrichard is offline   Reply With Quote
