Old 02-06-2014, 07:22 PM   #1
truckdude239
truckdude239's Avatar
temp sensor
what are yal doing for a tempo sensor tring to get stock guages hooke dup till i get the money for dokota digital guages i'd like to not have to drill the head on teh passager side as the engine is in the truck already.
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-06-2014, 09:46 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: temp sensor
You wont run the stock guage,without drilling to fit? I opted for an Auto meter 90 sweep elct guage & the adaptor /sensor to fit the app. longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-06-2014, 10:15 PM   #3
Jon01
Jon01's Avatar
Re: temp sensor
There is an adapter/sender setup I and many others have used. Do a search on my posts and you'll find it.
No drilling, both the adapter and sender are auto meter parts.
Jon01 is offline   Reply With Quote
Old 02-06-2014, 10:20 PM   #4
JJH Jimmy
JJH Jimmy's Avatar
Re: temp sensor
I drilled and tapped my water pump and put the sensor there.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 02-07-2014, 01:24 AM   #5
crazy longhorn
Re: temp sensor
My opinion, does not really make a diff on your truck....but I will lay my thoughts down? Think about what you are playing, also where you want to go Get your 'ducks in a row", for where you want to be....you shure dont want to play it, 2 or 3 times over? Longhorn
Old 02-07-2014, 08:52 AM   #6
Andy4639
Old member
Andy4639's Avatar
Wink Re: temp sensor
Mine is installed on the back passenger side of the block. I had a long senor and a short bushing that was right for the block threads.You can see the brass in the top of the picture.Reading is a little higher than the computer but thats OK, It reads around 200 with a 165 thermastat. The computer stay at around 175.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-07-2014, 09:57 AM   #7
truckdude239
Re: temp sensor
i agree with that but my issuse is i just bought a house and yes my swap is running i'm just trying to get the stock gauges to work till i can save up the 800 dollars for the Dakota digital gauges i want
David fuller
2000 Tahoe 5.3l 378
Old 02-07-2014, 11:51 AM   #8
Jon01
Jon01's Avatar
Re: temp sensor
My suggestion will cost about $20 and is way easier than drilling and tapping a head with the motor in the truck.
Old 02-07-2014, 01:32 PM   #9
akdg87
akdg87's Avatar
Re: temp sensor
grab yourself a 3 wire ls1 temp sensor, two of the outputs go to the ls pcm and the third output goes to your factory temp gauge, very simple no drilling and tapping, replaces the sensor on the drivers side head. You will need the pigtail for it though and its the same as the TPS sensor plug.
I dont think i paid over 20 bucks for mine: http://www.ebay.com/itm/like/380809605775?lpid=82
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 02-07-2014, 04:18 PM   #10
Houston Ben
Houston Ben's Avatar
Re: temp sensor
that really works??? Not questioning you just didn't know there was something like this out there. I did the same thing Andy4639 did but mine reads lower than my ScanGauge II. Man I wish I would have known this!!
GM part #12551708 for 98 Camaro but I think this one goes in the head??
Houston Ben is offline   Reply With Quote
Old 02-07-2014, 04:28 PM   #11
truckdude239
Re: temp sensor
I just bought a scan guage 2 untill i can get my money up
David fuller
2000 Tahoe 5.3l 378
Old 02-07-2014, 04:28 PM   #12
Andy4639
Old member
Andy4639's Avatar
Talking Re: temp sensor
My temp gauge is from Speed hut for the temperature gauge I got from them so it's not the stock gauge. But there are fittings that will work. I have also seen the 3 wire ls pigtail.
Old 02-07-2014, 08:01 PM   #13
ls1nova71
ls1nova71's Avatar
Re: temp sensor
I don't think the 98 F body 3 wire sender will work properly with the factory 67-72 gauge. It may move the needle but won't be accurate. Same goes for the autometer sender, although its closer. Somewhere on here I have a picture of a factory gauge hooked up to the autometer sender and a Tech2. At 195 a factory 67-72 gauge is right in the middle, but with the autometer sender its closer to the 1/4 mark. That said, I'm not sure how accurate a factory 40 year old gauge is anyway.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-07-2014, 08:18 PM   #14
Andy4639
Old member
Andy4639's Avatar
The 3 wire senor and pig tail is $57.00 at Hawks they have them in stock. I was looking at them while I waited for them to finish up the truck. As stated though I don't know how acrate it would be with the stock truck gauge.
I just ran across this.
http://www.classicdash.com/shopping/...ation-Kit.html
This kit includes the required sensor adapters for the oil pressure gauge and water temperature gauges. As well as a 10K Resistor for the tachometer.
The specialized instruction manual, fittings, sensor, and electrical component packaged in this kit make the instrument installation on your GM LS based engine simple and straight forward.
Old 02-08-2014, 01:42 AM   #15
truckdude239
Re: temp sensor
See thats what im talki g about
David fuller
2000 Tahoe 5.3l 378
Old 02-08-2014, 05:13 PM   #16
crazy longhorn
Re: temp sensor
Totally understand, while my house is finally "owned', it is still eating money in repairs I used the Autometer kit, listed @ the bottom of the page, & also had read that the sensor will work with the stock guage, but maybe not be right on for the read? If you test the temp, & know that the 195 spot is around 1/4 guage, or so....then you know where it is (should work for a temp solution) Best of fun, Longhorn
Old 02-08-2014, 05:59 PM   #17
68c10airstream
68c10airstream's Avatar
Re: temp sensor
Hi David, I drilled the face of the water pump and installed the stock sender. ls runs hotter than 1968 standards, gauge read about 3/4th scale. Installed a variable resistor potentiometer in-line and dialed the gauge down to read colder to the 1/2 scale i was looking for. If memory serves me correctly it was a 4 ohm 1/2 watt resistor. I shined up the sender brass terminal for good connections and consistency. Works spot on every time. Pulling the airstream in hot weather it runs about 5/8th scale, equal to about 208 degrees F. Good luck, Brian Fuller
68c10airstream is offline   Reply With Quote
