Old 02-07-2014, 05:49 AM   #1
karl
karl's Avatar
Speedo Needle??
77 C10. I hooked up the stock gauges and speedo cable and the needle is pointing straight down. When i drive it moves to the left but it is at least 20mph off for some reason. Whats wrong and can this be fixed? Thanks.
karl is offline   Reply With Quote
Old 02-07-2014, 01:57 PM   #2
dman1982
dman1982's Avatar
Re: Speedo Needle??
check out my last thread.... http://67-72chevytrucks.com/vboard/s...d.php?t=614496
sound familiar?
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 02-07-2014, 06:09 PM   #3
karl
karl's Avatar
Re: Speedo Needle??
No. mine doesnt bounce or skip. It climbs steady but the needle is at the 100mph mark when the truck is sitting still. The needle moves in the right direction. Dont get it?
Old 02-07-2014, 07:04 PM   #4
ray_mcavoy
Re: Speedo Needle??
The speedometer needle (like all the others) is a press fit onto a round shaft.
They usually fit tight enough so they don't move out of position, but it kind of sounds like that's what might have happened to yours.
Has the cluster been apart recently for cleaning or other work that could have accidentally disturbed the needle position? If that's the case, and it's working normally aside from the mis-positioned needle, you can probably fix it by carefully pulling the needle straight off the shaft and carefully pressing it back on so it's pointing at zero.
ray_mcavoy is offline   Reply With Quote
