Old 12-24-2003, 11:30 AM   #1
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
Grrr... TH400 kickdown connector, where is it?!?
Well, what should have been a 15-minute job turned out to be a bust. Why? Because I can't seem to locate with any sort of confidence where my kickdown is supposed to plug in at on this TH400. There appears to be only one place on the driver's side, but there's a wire that comes off of that connection, routes up and into the cab and up to the column.
Can anybody point me in the right direction here? Am I looking in the wrong place or did the PO screw it up?
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 12-24-2003, 12:35 PM   #2
Chevy67Tk
Chevy67Tk's Avatar
That would be the wire.
Check to see what the other end is hooked to on the column. PO may have used a throttle-activated switch out of something newer.
Chevy67Tk is offline   Reply With Quote
Old 12-24-2003, 01:06 PM   #3
JimKshortstep4x4
Talking
There are only two connections on the kickdown switch on a 71-72 and I assume that is what you have. Anyway here is a pic of the 71-72 style switch. The two terminal connections are on the back side as it is pictured. One is 12 volt power, the other is the wire that goes to the side of the transmission, (black wire).
Jim
Old 12-24-2003, 01:13 PM   #4
shuttermutt
So the one and only connection on the driver's side of the TH400 is for the kickdown, right? My kickdown is a throttle linkage activated doodad that takes 12v from the battery and makes a connection to the tranny.
How is the TH400's neutral safety hooked up? Is that handled via some other mechanism?
'Mutt
Old 12-24-2003, 05:00 PM   #5
gonebad2
Merciless Butcher
gonebad2's Avatar
Do yourself a huge favor. Get the kickdown kit from lokar. It's inexpensive, looks awesome and works like a dream.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 12-24-2003, 05:08 PM   #6
rage'nrat638
rage'nrat638's Avatar
combo reverse neutrel safety switch
the reverse side of the switch----------green wires
rage'nrat638 is offline   Reply With Quote
Old 12-24-2003, 05:10 PM   #7
rage'nrat638
another
the safety side of the switch purple wires
Old 12-24-2003, 09:31 PM   #8
shuttermutt
Perhaps, but it's real hard to beat holding in my hand now vs $70 to have it a week from now. The switch isn't the problem nor is the linkage or bracket. The problem is making damn sure I know where to plug this thing in at!
'Mutt
Old 12-24-2003, 09:32 PM   #9
shuttermutt
Hey Rage... is that under the dash? Cool pics, but I'm having a hard time getting my bearings on what I'm looking at.
'Mutt
Old 12-24-2003, 09:44 PM   #10
rage'nrat638
thats the combo reverse and neutrel safety switch at the base of the steering collium......the switch you asked about......
it's actavated by moving the gear selector.......
thats both side's of the switch
Old 12-24-2003, 10:12 PM   #11
photoglg
photoglg's Avatar
The kickdown solenoid is in the trans and the wire that comes out goes to the switch sometimes at the carb on the linkage, but as you can see sometimes under the dash. just put a switch in line from the solenoid to power that will activate when you step on the gas. I used a horn button on the floorboard.
1969 GMC S/B S/S 3" drop
photoglg is offline   Reply With Quote
Old 12-24-2003, 11:39 PM   #12
shuttermutt
Excellent! Thanks everybody!
'Mutt
