how do I remove the shift lever stock 4 speed trans?
I'm considering pulling my trans (engine is already out). Can someone tell me how to disconnect the shift lever? Do I just punch this pin out, or is there some trick?
1967 GMC 1500 SWB. Driving this truck since I was 14. |
Re: how do I remove the shift lever stock 4 speed trans?
That sheet metal retainer is a "cam lock".
Take a pair of channel locks and grab it at the top. Rotate while pressing down and it should twist right out. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Try using just your hand first. Press down on the ball and twist. It's a 90 degree thing as I recall.
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
Easiest way is a hammer and screw driver. Place the screwdriver tip in the corner at about a 45* angle. Give it a decent tap down and counter clockwise and it should come right out. If you can pull it with your hands there is an issue with the roll pins and they are not holding enough tension on the retainer. If that is the case the shifter should have a decent amount of slop. You can replace the roll pins or put a clamp around them to hold them taught.
It's not as hard as some people make it sound, just use your fingers to push the entire cup straight down, while it is in the down position, turn it to the left half way. It should pop up ! Now just lift out the Leaver. Hope that helps....
71 C-20 07 Magnum RT AWD |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Also make sure it's in neutral then push down on the cup (it's spring loaded). Then turn left and let it pop up and lift the shifter out. I usually do it by hand.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Thanks guys! Firm push on the ball and a quarter turn to the left and it popped right out!
Feels good doesn't it ! Know you think , that wasn't so hard was it ! Good job ! I felt the same way the first time I got one to come out !.....
No channel locks or hammers required! Just some man hands! Nice work!
BlahBlahBlah
I remember the first time I tried to figure this out on my own lol, couldn't believe how simple it was after someone told me the trick.
