Auxiliary / Isolated Oil Filters?
I was browsing pictures of 69 c10's on flickr and i came across this photo of two isolated oil filters on the underbody of a truck?
Can anyone explain whats going on here?
1966 GMC ShortStep |
Re: Auxiliary / Isolated Oil Filters?
the guy has an adapter that goes on the engine for the use of two oil filters instead of one// was used on very hi usage industerial type and or hi rpm racin motors a case of overkill on the street
#3 | |
I like the idea of the relocation, looks like it would be a little less messy during an oil change..
![]() Join Date: Apr 2013
Now all it needs to filter it better is get rid of those fram filters and replace them with AC Delco or Wix filters.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
How does one score a setup like that?
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves Jorge: Kia Roller-skate with lots of buttons for the wife Wovoka: 2017 Indian Chief Vintage, better on gas but not much So far, this is the oldest I've ever been. |
I wouldn't really say that its an overkill for a street engine since its just filtering oil and you never know whats really in your engine. However, I do know that if your not careful if you have alot of hose on top of two filters it might drop your pressure to low so your engine will starve of oil under higher demands.
1970 ![]() SBC350 / TH350 '84 C20 Front Disc Brakes/Control Arms |
![]() Join Date: Jan 2001
I remember Fram featuring a setup like that on a Camaro years ago in one of their commercials.
