Old 02-07-2014, 05:16 PM   #26
litew8
litew8's Avatar
Re: Picture request - factory vac gauge connections to the back of the dash
I agree with all the above comments. I'd suspect that the OEM vacuum on heavier ton trucks were used primarily to ensure good vacuum for braking and not so much the engine itself. That's not my intent. Mine is to monitor engine performance.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 02-10-2014, 09:48 PM   #27
jocko
jocko's Avatar
Thanks Tom, tin arrived today!
Old 02-10-2014, 11:05 PM   #28
TBONE1964
Cluster King
TBONE1964's Avatar
Great! I am glad you got it and with no damage.
I want pictures of the finished product
Take care,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 02-10-2014, 11:57 PM   #29
chewychevy67
yep, I'm a little cornfused also. I am assuming that is just your manifold vac tee and you're hooking a hard line to the vac gauge where you have the brass fitting screwed in? If that is the case, you will need to account for eng vs body vibe as was mentioned above. Even if a hard line is used, there has to be rubber in the process somewhere to account for that. Or I might not be interpreting what you're doing correctly.
Thanks for posting EVERYone - this has been very helpful to me.
I am going to put rubber in between the two ends. I am going to have a hardline under the hood and run into the grommet where the oil pressure runs and from there put a piece of rubber through the grommet about one inch towards the motor and make it look like part of the grommet. cleans it up a bit and looks more factory I think. I will run a rubber hose on the inside to the line on the gauge so it will be easier to remove from the dash. Ill post a pic of the grommet when I have it out next.
chewychevy67 is offline   Reply With Quote
Old 02-14-2014, 05:07 PM   #30
chewychevy67
this is how im doing mine. from under the hood it will look like a hard line and under the dash it will be rubber. this will make it much easier to remove the gauges as well. the fitting on the back of the gauge is factory from a 73-up gauge cluster.
gauge, vac, vacuum
