Old 02-10-2014, 09:05 PM   #1
NC_John
NC_John's Avatar
Gas filler neck seal
I just got a new gas filler seal (the rubber seal through the cab at the filler cap)- made by counterpart. It's too small and leaves unaged paint visible around it (a ring of shiny unfaded paint). Does anybody know of a better one available out there?
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 02-10-2014, 09:20 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Gas filler neck seal
I got one for my 69 from a vendor in Wisconsin a couple years ago. It was in original GM packaging. Try your local Chevy dealer and ask if they are still available from GM for your year.
FirstOwner69 is offline   Reply With Quote
Old 02-10-2014, 09:36 PM   #3
NC67Chev
NC67Chev's Avatar
Ever come up to Winston Salem? This appears to be a GM seal:
http://www.classicmuscle.com/p-45774...l-1-34-id.aspx
You can give them a call to make sure it's not a repro.
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 02-10-2014, 09:44 PM   #4
NC67Chev
NC67Chev's Avatar
Sorry, I thought I saw '72 in your, but now I see you have a '70.
http://www.classicmuscle.com/p-45770...seal-2-id.aspx
Old 02-10-2014, 09:47 PM   #5
NC_John
NC_John's Avatar
LOL- that was where I got the counterpart seal from..... Mine is a '70 too so that part, if they still have it, won't fit. I've found with classic muscle a lot of the stuff they have in their catalog as NOS GM is long gone and they ain't getting more!
I did get official GM door pins and bushings though.
I hate that those guys are closed Saturdays. I had a buddy that works in kernersville run over there at lunch today and pick up my order for me.
1970 C-10 LWB "Blu"
Old 02-10-2014, 09:48 PM   #6
NC_John
NC_John's Avatar
Yeah, no problem....
I see you have power drum brakes.... Did you add the booster or did the truck already have it?
Added: whoops, see you have it listed as an upgrade- how do they compare before and after the booster?
1970 C-10 LWB "Blu"
Old 02-10-2014, 09:51 PM   #7
NC_John
NC_John's Avatar
My wife works at a chevy dealer.... I might get her to try parts tomorrow and see if I get lucky. Anybody got a PN?
1970 C-10 LWB "Blu"
Old 02-10-2014, 09:55 PM   #8
NC_John
NC_John's Avatar
Answered my own question.....3886792.....
1970 C-10 LWB "Blu"
Old 02-10-2014, 09:59 PM   #9
litew8
litew8's Avatar
Have any pics? Does it look like this one?
on ebay
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 02-10-2014, 10:01 PM   #10
NC_John
NC_John's Avatar
on ebay
That looks like the 71-72. I found one on ebay I bid on just a few minutes ago.
1970 C-10 LWB "Blu"
Old 02-10-2014, 10:04 PM   #11
litew8
litew8's Avatar
I didn't know there were different ones for different years. 71-72 are different than the rest?
Old 02-10-2014, 10:20 PM   #12
NC67Chev
NC67Chev's Avatar
I added it. My front hoses needed replaced, which led to needing new lines.... I knew I wanted to eventually go with disc brakes, so I put the booster on as I was replacing the lines and master cylinder. I actually have a disc brake set-up that I'll be putting on as soon as I have time.
Adding a booster obviously doesn't make the brakes any better...you just don't have to push very hard. The only reason I put the booster on was because I wanted to eventually go with discs.
Old 02-10-2014, 11:34 PM   #13
FirstOwner69
See post 4 in this thread for GM part numbers.
http://67-72chevytrucks.com/vboard/s...d.php?t=115346
The link to the vendor where I got my GM grommet a couple years ago is below. The grommets are near the bottom of the page with the GM part numbers. Give him a call and find out if they are still GM issue.
Old 02-10-2014, 11:55 PM   #14
Tillik
Tillik's Avatar
Ya i ordered one thru Ecklers Truck parts. It cracked and fell apart in less then two months. Let me know if you find a good one.
James B.
1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful)
1971 Chevy Fleetside Shortbed 4X4 (White & Rough)
Tillik is offline   Reply With Quote
Old 02-11-2014, 02:51 AM   #15
19Chevy67C10
19Chevy67C10's Avatar
Speak with Wes at Classic Heart Beat in Washington he is a board vendor and I believe he has them custom made and they fit!
Kev's-C-10
19Chevy67C10 is offline   Reply With Quote
Old 02-11-2014, 10:19 AM   #16
Lee H
Lee H's Avatar
The GM grommets being sold now days (bar code packaging) do not hold up well, I went through two of them a few years ago, cracked in the sun in just a few months. I now have one from Classic Heartbeat, no signs of cracking or weathering so far, it's been on little over a year.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
