02-10-2014, 08:10 PM | #1 |
Advice? When to install CAM? Before or after swap?
I plan to put a CAM in a 5.3L that I am swapping into an 81 C10 SWB. I have not heard the motor run, (supposed to have around 60k on it). I damn near have the motor tore down just checking to make sure all looks good (heads and oil pan are off). But I am wondering when I should install the CAM?????? It would be easier to do it now while I have the engine on the stand. But would it be better to wait until the swap is done and know I have a good running motor and any bugs worked out???? Your thoughts appreciated! |
02-10-2014, 08:14 PM | #2 |
Re: Advice? When to install CAM? Before or after swap?
Do it before you put the motor in the truck these ls motor done normally go bad mine sit for u months in a wrecking yard then almost a year while swaping and still fired right up
02-10-2014, 08:22 PM | #3 |
i'd do it now if i were you, it sucks taking stuff apart that you just put together! if everything looks good that you can see now-you should have nothing to worry about.
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold 1986 suburban 350/700r/3:73's 31's: parted out. 1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold 1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold 1970 c10 long bed-new project! getting ready for the 6.0 |
02-10-2014, 08:59 PM | #4 |
Freakin Awesome!
I'm in your position myself. I think I've just decided to install it and run it for a while to see how I like it. My Blazer has been down for almost a decade though so I'm anxious to get it on the road.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee |
02-11-2014, 11:49 AM | #5 |
If you know you want to install a cam (and valve springs), do it before putting the engine in the chassis. As long as all the cam lobes on the original engine look to be in good shape, I wouldn't worry about the condition of the engine too much - worst case is you may have to put the cam into your next motor.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
02-11-2014, 11:52 AM | #6 |
Now.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-11-2014, 12:13 PM | #7 |
i'm in a similar spot as you and i'm gonna get it swapped and running as a stocker.
get into the learning curve with tuning on a stock mill and then tune the bolt-ons as I go well that was the plan until I was offered a killer deal on a p1sc....goodbye all my money forever... |
02-11-2014, 12:20 PM | #8 |
I would get the stocker running. Changing too many things at once is often a recipe for disaster. It would be hard to go back to the person that sold a bad engine to you after you've swapped a cam. Besides, it would be good to have a comparison with your new cam to stock.
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
02-11-2014, 03:21 PM | #9 |
all valid points however I would also do it now before the install especially if you are going to do it soon.
I ran mine stock for a year or so before the swap but I ended up pulling the motor again to make it easier. I would do it now.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
02-11-2014, 04:07 PM | #10 | |
Boosted Member
Why is this even a question?? If you have the parts already (cam, springs, pushrods, etc) do it now.
Even my "bad" busted up turbo motor ran pretty awesome with 4 bent rods, and 5 cracked pistons.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
02-11-2014, 04:33 PM | #11 | |
02-11-2014, 05:03 PM | #12 | |
Boosted Member
However, it may stay just as it is, during "mockup" phase for another few years at least. It's just too much darn fun to drive as it is. But yes, I understand your reasoning.
02-11-2014, 05:08 PM | #13 |
I absolutely reserve the right to keep my stuff in "mockup" phase indefinitely! Lol!
Jeff
