Old 02-09-2014, 08:43 PM   #1
Andy4639
Old member
Andy4639's Avatar
Question Heavy duty carrier bearing
I know this has been talked about a bunch on here but who has the best price on the Heavy duty carrier bearing with billet support like in the picture. I have found a couple of prices but figured I ask here first before I spend the money.
So post up guy's with the best prices.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-09-2014, 11:07 PM   #2
kamikazekyle05
kamikazekyle05's Avatar
Re: Heavy duty carrier bearing
I'm interested also
kamikazekyle05 is offline   Reply With Quote
Old 02-10-2014, 12:01 AM   #3
brad_man_72
the boat guy
brad_man_72's Avatar
You also have to add the price of adding a slip and stub to the rear shaft and having both shafts ballanced together. You're probably better off taking it to your local driveline shop and getting an estimate for all of the parts and labor. A lot of people don't like when customers bring in parts that they sell (and prices for the other work goes up).
This carrier bearing is a great way to spend $250 to fix a $60 ballance problem.
If you're breaking carrier bearing mounts and just want to fix the symptom, welding some braces on a stock style carrier bearing is a lot cheaper.
brad_man_72 is offline   Reply With Quote
Old 02-10-2014, 05:56 AM   #4
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I gave $12 dollars for this one Andy...I figured if the last one lasted 40 years, this one will get me home... That was two or three years ago... I replaced the flexplate a couple of months ago and that $12 dollar carrier bearing is still tight and shines like new!
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 02-10-2014, 08:38 AM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: Heavy duty carrier bearing
Mine is been done for almost 10 years now and yes it has been modified twice now. Once for the 700r4 and last week for the new 4l80e. I know all about the shaft and balancing it guy's I just want to know where the best price is for one of the billet carrier's.
brad_man_72 If you're breaking carrier bearing mounts and just want to fix the symptom, welding some braces on a stock style carrier bearing is a lot cheaper.
Can you show pictures of this!
I have never broke them but have worn several of these out over the past 26 years.
Old 02-10-2014, 04:25 PM   #6
FirstOwner69
FirstOwner69's Avatar
The best price I see in the few catalogs I have is at Classic Industries for $114.99. Also, you can get 15% off that with the code I just posted in the promo code thread. That gets the price down to about $97.75 if you act before midnight on the 14th. Part number is CS5801. If you wait, it is very common for them to offer 20% off.
FirstOwner69 is offline   Reply With Quote
Old 02-10-2014, 04:38 PM   #7
Fldawg
Fldawg's Avatar
i'm not a big fan of the urethane bushings, they don't give like the others and sometime they will squeck. after going thru 2 made in the land of the rising sun, i bought a bca bearing made in canada and its held up ever since and that's been 2 years ago
Fldawg is offline   Reply With Quote
Old 02-10-2014, 09:58 PM   #8
Andy4639
Old member
Andy4639's Avatar
Wink Re: Heavy duty carrier bearing
Thanks for the heads up but I found one on e bay this morning for $95.00 shipped. I ordered it today.
Fldawg,
I hope it last longer than the standard ones do. I'm going on about 8 years on the one in the truck now. I hope it doesn't squeak though.
Old 02-10-2014, 10:04 PM   #9
truckdude239
truckdude239's Avatar
I read somewhere you have to add a slip joint to run that style bearing
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-10-2014, 10:46 PM   #10
brad_man_72
the boat guy
Welding the T is all I have a pic of and the easiest way to add some strength to the stock mount. You can also brace the sides with a 1/2" wide piece of steel from the top sides of the T down to the sides of the O. I hope I explained that to where somebody will understand.
Yes you have to run a slip and stub to use the billet mount.
The actual bearing in the billet carriers is the same that comes in the factory style, so if the bearing goes bad you can buy the cheap assembly to rob the bearing out of it.
I've always seen them around $100, I never looked to see what we paid for them wholesale. Sounds like you did good on price.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
Old 02-10-2014, 11:02 PM   #11
Sicklajoie
The Niner
Sicklajoie's Avatar
That's exactly what I did with mine after the cheap Chinese spot welding job gave out:
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 02-11-2014, 12:21 PM   #12
71 super
71 super's Avatar
I used one of the billet units in my 68 and no problems. If you are going for performance dont know that it helps, but if visual impact for shows then this is way to go.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 02-11-2014, 02:01 PM   #13
leftybass209
leftybass209's Avatar
I'm glad this issue was brought to light recently. I have to change mine out soon and was on the fence of which one to buy. I'm happy to know I can get away with the cheaper one and some welding. Thanks for bringing this up and best of luck with your new carrier Andy4639.
leftybass209 is offline   Reply With Quote
Old 02-11-2014, 03:19 PM   #14
Andy4639
Old member
Andy4639's Avatar
Well I'm sorta going for performance since I just did the 6.0 LSx motor swap and the 4l80e transmission but not that much. I just figured it was a good upgrade. I don't know about the slip joint stuff though.I thought it was a direct replacement for the 2 peice drive shaft.
Old 02-11-2014, 04:43 PM   #15
71 super
71 super's Avatar
It is a direct replacement I don't have a slip joint, just standard two piece shaft
Old 02-11-2014, 05:21 PM   #16
brad_man_72
the boat guy
It might fit the same but it certainly doesn't function the same.
As the suspension moves the driveshaft will move foreward and back, the factory rubber was very soft allowing this movement. The billet/poly mount is very rigid and doesn't allow for any movement (in any direction). A trailing arm truck doesn't have as much movement as any other type of suspension but there is some movement.
Can you get away with not having a slip and stub in the rear shaft with a billet/poly bearing, possibly. Is it correct, no.
If you're breaking carrier mounts because your shaft isn't ballanced and don't want to ballance your shaft. Reinforcing a stock bearing mount is cheaper and better than the billet/poly mount. They do look cooler, ill give them that.
Old 02-11-2014, 05:38 PM   #17
Andy4639
Old member
Andy4639's Avatar
I haven't broken one in over 15 years. I have worn the rubber out though. I want it for longtivite if nothing else. I had the shaft shortened when I did the 700r4 years ago. I had the same shaft done again a week ago for the 4l80e transmission and it's never given me any trouble. I always had them balanced after cutting them. here it is today.
Old 02-11-2014, 06:14 PM   #18
Andy4639
Old member
Andy4639's Avatar
Here is how it's sitting now.
Old 02-11-2014, 09:13 PM   #19
71 super
71 super's Avatar
Is the slip joint at the trans not for the movement and the carrier bearing is exactly that a carrier OR support bearing? Considering the shaft actually has a slight angle change just beyond the support bearing and the support is rigidly mounted with the shaft rotating via the bearing, why is a second slip joint needed? I have personally had the vehicle that I have the poly bearing installed on at well over 100 mph at charlotte motor speedway with this bearing in place and NO vibration, mass chaos or other catastrophic failures. I think that qualifies for a pretty good shake down of a part. Is the poly support needed, no, is it better than the Taiwan 25 dollar units yes. Andy I have had problem with the stock type replacements and they as pictures prove are not constructed like the originals and the mid joint on a two piece shaft is a big enough pain to take apart that I did not want to do it every two years. My 68 does not see much driving, but if given the option I would purchase the unit again. I offer this based on my experience with BOTH types of supports and this is a much better constructed unit than the cheaply made parts house replacements.
Old 02-11-2014, 09:24 PM   #20
Andy4639
Old member
Andy4639's Avatar
Well thank you. I have already bought the bearing and I plan to install it for just that reason peice of mind. I hope!
Old 02-12-2014, 10:42 AM   #21
brad_man_72
the boat guy
I have just a little bit of experience, I've built thousands of driveshafts. Including a few dozen with this style carrier bearing for both cars and trucks. So take anything I say with a grain of salt.
You had your shaft cut down and ballanced a few weeks ago and want to redo it again?
Whoever ballanced your shaft put the center weight on the front shaft instead of the rear, welding a weight on the front shaft can warp the stub that the carrier bearing goes through. Definetly not something id do because I like to ballance shafts quickly the first time.
Old 02-12-2014, 11:01 AM   #22
brad_man_72
the boat guy
That's exactly how the stock carrier bearing works because the carrier bearing rubber is very soft.
With the billet/poly carrier bearing the driveshaft is mounted solid to the frame and the rear end. So the trans slip yoke only slides if the engine is moving fore and aft in the frame.
In theory the engine should be mounted pretty sturdy to the frame, and the rear end is mounted solid to the moving suspension. I prefer not to mount something solid to the frame and solid to the moving suspension.
99% of every other multiple piece driveline setup they use a carrier bearing more solid than this style, they also will always have a slip yoke in the rear shaft to account for rear end movement unless IRS. In every single RWD one piece driveline that isn't in a newish corvette the shaft has a slip joint.
Exactly zero automotive manufactures us a carrier bearing as solid as the billet/poly unit. Not even for semi trucks. Not even with a slip in the rear shaft.
Old 02-12-2014, 03:01 PM   #23
Andy4639
Old member
Andy4639's Avatar
I had the shop that swapped the motor do the drive line. This is how they did it. I have another shaft I plan to take the measurements off of this one and have it cut down with all new bearings and yokes and whatever else I need. The shaft seems OK but I had questions on it ever since they did it. The poly bearing will be more of a show peice it looks like more than anything else.
Old 02-12-2014, 11:11 PM   #24
airdale94
airdale94's Avatar
All driveshafts need slip somewhere whether it's a 2-piece or 1 solid. It can be at the trans. tailshaft. Or if your trans. has a flange (bolt and strap) like at the differential, the slip has to be incorporated into the driveshaft.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 02-13-2014, 10:43 AM   #25
brad_man_72
the boat guy
The slip has to be between the rear end and the frame. The stock soft carrier allowed some movement. Making the trans tailshaft the only part solid mounted to the frame, so that's where the factory had the only slip.
