02-10-2014, 06:05 PM | #1 |
How much to have 700 R4 installed
I'm going to have to change out the tranny - it's pi$$ing fluid all over and rattles and grinds like nobody's business - to have the leaks stopped is several hours work and several hours work may as well be done installing a new one. This is NOT something that I could tackle myself at all. Question is how much should i be paying for it on top of the cost of the transmission itself? How long does it take? Another question is, currently vehicle has 4" lift. When I lower it back to stock, will there need to be further work on the transmission as the distance to the Rear axle will shorten very slightly?
02-11-2014, 08:44 PM | #2 |
I know the pieces fit
Re: How much to have 700 R4 installed
I'm guessing at least $300 to $400 over the price of the new tranny.
02-12-2014, 12:54 AM | #3 |
Thats indicating it s a 5 -7 hour job maybe? Can I ask what is the ballpark hourly rate is where you are? Here it is $85 or $120 depending upon where you go so this would be about $500 to $700 extra here
02-12-2014, 07:19 AM | #4 |
I'm sure prices will run a little higher in CA over AL, but still I'm probably low. I found out the other day the tranny guy I know gets $700 to rebuild a TH350 now - blew my mind... I think rates are around $70/hr here.
02-12-2014, 07:29 AM | #5 |
Moderator
I think if you call around the difference between a carry-in transmission and the full remove/replace isn't that big. Here in Missouri you can get a 2wd 700r4 rebuilt and R&R'd for $700-800. I would expect to pay more like $1200 for a 4wd at a larger shop.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
