454 BBC Swap
I know this forum is riddled with 454 swap threads and build logs, but I haven't quite found what I have been looking for.... So, Here we go.
I have a 1969 C-10 with a later model 350 crate sitting between the frame rails. I have been told that the motor runs, but I haven't been able to verify for many reasons. BUT, I have some ideas for my self. My manager has a 1999 Suburban 2500 that is fully functioning other than the trany, that's no big deal. He will sell it to me for $1500. My idea is to take the Vortec 7.4L (454) out along with many other parts like all the serpentine system, the AC Compressor (wanting to add to a Vintage air system later), FUEL INJECTION ![]() This is my inspiration for the 454. This is a user on this board's truck. (I can't remember who it is) But I would like for it to look a lot like this. May not be possible unless it has a TBI, which it doesn't. Would it be worth it for a parts vehicle?
1969 ![]() 2015 GMC 2500 Duramax (Daily Driver) 1999 Jeep TJ 2010 Harley Street Glide Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981 |
2WD Jimmy
![]() Join Date: Mar 2005
Re: 454 BBC Swap
How many miles on it?
Re: 454 BBC Swap
Somewhere in the upper 2's lowers 300,000's I'm planning on a full rebuild, a over bore, and a cam. This will of course will lead to an ECU reprogram too.
If I were to pull a 454 out of a Junk yard and buy an Ez EFI system I'm already looking at close to $2000 with out a rebuild or any of the running gear.
Re: 454 BBC Swap
You can do what you are talking about doing. It is possible to put a late 454 in an early vehicle. I assume you will use the 4L80 trans and have it rebuilt? If was going to go to all the trouble, I would go with an LS. But either way it would definitely be fuel injected. You are on the right track.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
Re: 454 BBC Swap
The LS is always a sweet way to go, but my money tree doesn't produce as much as others...
