Old 02-13-2014, 12:24 PM   #1
SeTx67
SeTx67's Avatar
CPP slider engine mount plates?
Has anyone tried these out yet? I was thinking about trying the ls1-kulac which is the one that allows you to run low mount a/c. Just looking for a little feedback before I call Jeff and pull the trigger on a set. Thanks in advance
SeTx67 is offline   Reply With Quote
Old 02-13-2014, 07:37 PM   #2
66LSx
66LSx's Avatar
Re: CPP slider engine mount plates?
They look okay... but I opted for the dirty dingos soley due to their history of working.... and for the 4 bolts holding the outboard slider... vs. the 2 that CPP uses... (for what thats worth)
I did use CPP sheetmetal motor mounts...
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 02-13-2014, 08:54 PM   #3
SeTx67
SeTx67's Avatar
Thanks for the info. I knew the DD looked beefier. Do the DD allow for low mount A/C on a 67-72? I'm thinking about keeping my A/C and power steering mounted low to avoid having to buy more parts
I tried a few quick searches for the CPP sliders and couldn't find any feedback. I talked to Jeff about them a short while back and from what I gathered I thought they were a fairly new product.
Old 02-13-2014, 09:26 PM   #4
66LSx
66LSx's Avatar
Yea they haven't been on the market long... I'm assuming the sliders came about somewhere near the sheet metal motor mounts timeframe wise.
Motor postioning (and consequently where the slider plate is in relation to the front of the motor) will play a VERY large roll on whether or not it interferes with the back of the PS pump or AC unit...
I think the AC would be a stretch with any slider.......
1966 C10 SWB Fleet
Old 02-13-2014, 09:38 PM   #5
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Lower AC will not work with Dingo Sliders...
They bolt over the top of where that bracket mounts... you will need to look at a relocation... Holley makes a nice high mount setup...
chevyguy_72 is offline   Reply With Quote
Old 02-13-2014, 09:48 PM   #6
truckdude239
truckdude239's Avatar
Dd mounts will not allow the low mount compressor i had to remove the ac mount to bolt my dd sliders up
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-13-2014, 09:58 PM   #7
SeTx67
SeTx67's Avatar
The part number I posted above cpp ls1-kulac is supposed to allow for low mount ac. Thanks for the info and confirming that the DD will not work for what I'm looking for
Old 02-16-2014, 05:30 PM   #8
boynton
boynton's Avatar
I am going with an ly6 with 6l90 and don't want to relocate anything either. Let me know how those work. I will be running stock height/close to. Also do y'all know if I will need to swap oil pans?
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 02-16-2014, 05:51 PM   #9
66LSx
66LSx's Avatar
I did NOT have to switch out the truck oil pan...it worked great actually.... although it IS lower than the cross member(trans and front k-member) and if your a severely lowered truck... I would consider switching to an F body or caddy or h2? oil pan so that the oil pan ISNT the lowest part of the truck.
mine fit great...
1966 C10 SWB Fleet
Old 02-16-2014, 11:34 PM   #10
SeTx67
SeTx67's Avatar
After speaking with Jeff at CPP I ordered a set Saturday. The sliders were out of stock but should be back in stock this week. Hopefully I'll get them by early march and see how they work out.
Boynton: I couldn't tell you on the ly6 pan. I had to swap mine since the tbss pan is a front sump so I went with the cts-v pan
Old 02-16-2014, 11:55 PM   #11
68c10airstream
68c10airstream's Avatar
Hi Boynton, my 5.3 with the stock truck oil pan sat about 1 1/2- 2" below crossmember so when i did an engine overhaul recently i swapped in a 98-02 camaro/ firebird ls1 pan and all is well. bottom of pan is now about 1" above crossmember. I used the 2001 truck organ donor mounts and made my own perches. Works well with trailblazer a/c compressor. If i was to do it all over again i would source everything from trailblazer-envoy-rainer 5.3/6.0 for the mounts, a/c compressor (suction/discharge ports in-line front to back) motor mounts with the cast iron brackets to engine, a/c lines and possible condenser out front. Good luck, Brian F.
68c10airstream is offline   Reply With Quote
Old 05-11-2014, 08:44 PM   #12
Blazerowner
Blazerowner's Avatar
I was reading the tread and wondered if SeTx67 ended up using the mounts and how they worked with the A/C.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 05-18-2014, 12:44 PM   #13
SeTx67
SeTx67's Avatar
Yes I used the mounts but still haven't finished my swap yet. They did allow clearance for the stock tbss ac bracket and compressor but I won't be able to use the stock bracket. The stock tbss bracket has two lower bolts that bolt to the tbss oil pan and I switched to a ctsv pan so that caused issues. I may try to pick up a truck bracket and see if that will work with the tbss compressor. If not I may use the holley brackets and mount the ac up high. As of right now I still need to finish a few things up so I can drive the truck but I'm close. Ac isn't a priority but will be soon with the Texas heat coming lol. My build thread link is in my signature but I don't think there's any real good pics of the sliders
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435
Old 05-19-2014, 10:52 AM   #14
Jonboy
Slots go on anything!
I think I may have a truck bracket I pulled off of mine. If you don't turn one up locally let me know. I will probably have to look for it.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 05-19-2014, 11:17 AM   #15
SeTx67
SeTx67's Avatar
Let me know if you find it. I haven't looked for one locally yet but it would probably be easier to find one on line
Old 05-19-2014, 04:04 PM   #16
chevyguy_72
Vintage Evil
I have one as well... I am not going to use it...
