Old 02-13-2014, 01:26 PM   #1
draggin49
help with leaking carb....
So I went into town like I do every morning to get a cup of coffee.
Fired it up, let it warm up. Get going and suddenly the thing will hardly idle and is running super rough.it had been running great. Its a gm crate motor, all new accessories, new edelbrock 600cfm electric choke carb.
It died on me once on my way limping it home.
I get out , pop the hood and its visibly leaking gas!!
I snapped a pic of the spot on the carb where its leaking. I noticed there was a visible gap and that little piece was loose, its on the left hand side of the carb near the back
draggin49 is offline   Reply With Quote
Old 02-13-2014, 02:38 PM   #2
Molberg
Molberg's Avatar
Re: help with leaking carb....
Hard to tell by your pic... Usually if it's pouring gas into/out of the carb it's either a sunken float... Or stuck needle and seat in my experience. Pop the top off the carb and see if your float is laying in the bottom. My old edelbrock afb left me in the side of the highway once. Brass float got a pin hole along the soldered seam ... And it sunk.
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 02-13-2014, 03:08 PM   #3
draggin49
Ok, the plate is stuck I'm the upright position, barely will move a 1/4"
It seems to be hung up on this threaded screw
Do I need to unscrew that so it sits lower for no interference???so that the piece can have full range of motion??
Old 02-13-2014, 03:23 PM   #4
geezer#99
geezer#99's Avatar
No that screw is normal. It's for the high idle.
Open the throttle slightly and you should be able to close the choke slightly by hand and the screw will then be riding on the cam.
Do you have a fuel regulator?
geezer#99 is online now   Reply With Quote
Old 02-13-2014, 04:54 PM   #5
draggin49
Hmmm, took it around the block, and it was fine.
Old 02-13-2014, 05:09 PM   #6
draggin49
But as I moved the throttle cable/linkage , the screw kept getting the fast idle linkage caught on it
Old 02-13-2014, 05:40 PM   #7
geezer#99
geezer#99's Avatar
It ran fine cause you had some crap in the needle/seat and now it's gone into the carb.
And for the second part, if it went on a high idle (the screw was resting on the cam) then your choke is set too rich.
Old 02-13-2014, 07:09 PM   #8
draggin49
It never went on a high idle, it started off running normal/idling normal then it felt like it were running out of gas, so it was sputtering and idling rough.
Old 02-13-2014, 07:33 PM   #9
geezer#99
geezer#99's Avatar
So!
The high idle cam that's held on by the torx type screw.
Do you mean the high idle screw gets stuck behind the cam and not ride on top of it.
Is the screw tight?
Old 02-13-2014, 07:56 PM   #10
draggin49
It was stuck, i backed the screw out a tad.now it looks like this position in the diagram:
Old 02-13-2014, 08:16 PM   #11
geezer#99
geezer#99's Avatar
If it was hanging up it would be closing your choke plate making it run rich and rough.
Hopefully it stays put.
Old 02-13-2014, 08:45 PM   #12
draggin49
Thanks so much for the help, gonna drive it in a little bit, ill report back if I notice anything.
