02-10-2014, 07:33 PM | #176 |
Re: What did you do to your truck today? Chapter II
beautiful. Yup, if I ever do a bed again, I'm taking it off the truck and standing it up...for sure!
Figure out what you want--then figure out what you are willing to give up to get it. |
02-10-2014, 11:51 PM | #177 |
Attachment 1213108I got my step side box all disassembled and started stripping the box sides.
02-11-2014, 12:46 AM | #178 |
shifter install
02-11-2014, 01:37 AM | #179 |
I visited it in the body shop , the 1936 Rolls Royce got finished and was leaving as I arrived so hopefully Guillermo will soon begin to work on it .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
02-11-2014, 03:11 AM | #180 |
Disassembly and cleaning.hopefully paint tommorow.really excited for the results.
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
02-12-2014, 07:11 PM | #181 |
RAT1968 '68 Cab/'71 Parts
Picked up my heads from Redman's Machine in Oakhurst today. Newly refurbished 062 heads with new 1.94/1.60 valves,
new springs, and and the shop's pocket porting. I took the heads in with the old springs, rockers and valves still attached....$550.66. I paid $300. The "Boss" settled up for the rest as a Valentine's Day treat for me.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
02-12-2014, 07:36 PM | #182 | |
Nice.... |
02-12-2014, 08:55 PM | #183 |
Bought the complete wiring harness a new rear bumper and installation kit and a new grill shell. Got the rear bumper installed and gonna work on the grill this weekend!!
02-12-2014, 09:14 PM | #184 |
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!! |
02-12-2014, 11:39 PM | #185 |
Ran the block number on my "new" motor...found out its not 350. Its 305. Same size block different bore. But its OK, because the mechanic that sold it to me is a standup guy. Im gonna get my money back and return the motor.I had already cleaned and primed it.oh well, more money towards my 350.also cleaned and painted inside frame rails and partial firewall. Also cleaned and painted trans member and motor mount brackets.picked up grade 8 bolts to reinstall both. New motor mounts came in. Received my '72 service manual I had ordered online.
02-13-2014, 11:18 AM | #186 |
Ordered all my parts for the cam upgrade.. Darn pesky lifter tap
02-13-2014, 08:41 PM | #187 |
Getting ready to install the fuel pressure regulator, I went out and looked at the fuel pressure gauge. it wasn't at 15, the way it seemed to be pegged on the last start-up.
It was at around 9.5. Just sitting there. No electric fuel pump "on"....So, first I pulled the gauge. It *did* move. To 7.5...while it was off. No pressure. There is a screw at the back I figured was an adjusting screw. I adjusted it. No dice. Couldn't get another one today, so I installed the fuel pressure regulator, hard and soft lines. Screwed the fuel pressure gauge back in. Fixed a couple of trouble spots. I think it showed 12 when adjusted all the way out ("most clogged") while the ignition was on and the motor was not running. When I started it up, the gauge reads "9". Guess I better get a new gauge.
02-13-2014, 11:46 PM | #188 |
Started my ZZ4 with FIRST TPI, for the first time.
Click on the photo to hear it run and click on my build thread to see more.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
02-13-2014, 11:53 PM | #189 |
02-14-2014, 09:28 PM | #190 |
Z10..sounds good. looks good also. like it a lot....
02-14-2014, 11:04 PM | #191 |
Put the new grill on today!!
02-14-2014, 11:46 PM | #192 |
02-15-2014, 02:28 AM | #193 |
Started project Windows, Picked up the one piece window kit(no wing window) & started the the change over & mods. will post pictures later.
02-15-2014, 03:27 AM | #194 |
Wednesday, just as the big storm Pax was getting started, I mailed off my shipping payment to get my 1968 stepside spare tire cutout fender sent to me.
I'll have to figure out where to put that as my garage is pretty packed up. |
02-16-2014, 01:13 AM | #195 |
02-16-2014, 01:42 AM | #196 |
1 piece window did pass door today
02-16-2014, 01:45 AM | #197 |
Pulled the column to fix the 3ott shift issues I've been having( no 2nd or 3rd gear), got that repaired and shortened the column length. Not sure how well the linkage is gonna fit but ill tackle that tomorrow.
-Sterling GIG EM' AGGIES!!!! WHOOOOOOP!!!!! "Whether you think you can or think you can't, you're Right." -Henry Ford 1972 chevy lwb 1934 ford p/u |
02-16-2014, 07:51 AM | #198 |
US Army Veteran
I could hear that all the way down here! Very nice. Guess I'm not the only one with a '72 tag in a hundred mile radius!
1972 C10 Highlander - The making of a daily driver |
02-17-2014, 11:47 AM | #199 |
English Chevy Owner
Washed the winters green slime off her, hopefully this year I'll get some time to do some serious work on getting her back on the road. Been accumulating parts for years now.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
02-17-2014, 01:16 PM | #200 |
Got the intake bolted on, carb bolted on, cable bracket on, throttle and kickdown hooked up, and dizzy stabbed and set at TDC. Just need to change the oil, install the cap and wires, and toss some fuel in it so I can time it.
Also found the casting numbers on my heads. They are 14014416.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast! Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun. 1st BN 3rd MAR. '00-'04 |
