Old 02-14-2014, 01:19 AM   #1
krazy_texan
krazy_texan's Avatar
Cat delete
So previous owner removed the cats from my 1990 suburban because of this while driving on the highway or for longer periods of time the o2 sensor sets off the check engine light. Kinda annoying. Is there a way to bypass this without putting cats back on the truck
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 02-14-2014, 01:54 AM   #2
andrewmp6
Re: Cat delete
Why not have some cheap high flow ones put back on it?
Old 02-14-2014, 06:53 AM   #3
79Betty
79Betty's Avatar
Re: Cat delete
^ high flow ones are pretty much a straight pipe with a cage around it. Looks like a cat but isn't.inspector is happy for the looks and you're happy for the performance... Win win!!
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 02-14-2014, 07:25 AM   #4
BigBlocksRule
Re: Cat delete
Electrical tape over the Check Engine light...
BigBlocksRule is offline   Reply With Quote
Old 02-14-2014, 07:34 AM   #5
Greenlee
Greenlee's Avatar
Re: Cat delete
Maybe try a heated 3 wire 02 sensor. You run the extra 2 wires to keyed power and ground. I use one with headers and no cats and the check engine light doesn't come on.
Greenlee is offline   Reply With Quote
Old 02-14-2014, 06:22 PM   #6
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Cat delete
I've never had cats on my 91 and its never had a CEL...
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 02-15-2014, 12:00 AM   #7
Zane M
Re: Cat delete
How did you come to the conclusion that your lack of cats is causing the O2 sensor reading to trip the CEL?
Are you sure the issue isn't the 02 sensor itself?
Since the 02 sensors are upstream of the cat in these trucks, the lack of a cat should have little to no bearing on the readings the 02 sensor is sending to the ECM.
Zane M is offline   Reply With Quote
Old 02-15-2014, 12:37 AM   #8
bnoon
Re: Cat delete
Agreed, single O2 systems have no knowledge of the catalytic converter being gone. '96 and later GM's had two sets of O2's, one ahead and one behind the cat, and the comparision of the downstream cat to the upstream one and those can see when a cat is missing.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 02-15-2014, 05:58 PM   #9
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: Cat delete
Me neither! The O2 is before the cat on these old trucks so the ECM will not care, or even know, if there is a CAT present or not. I agree with Zane, something else is going on.
It is a Federal Crime to remove the cats but it is okay to use a “test pipe”. I’ve been testing this “Test Pipe" for a few years on my ’89 Burb and so far the “test” is going well. I think I will keep “testing” it for a while longer. The CEL has never come on either.
“Test pipe” viewable on the far left
DirtyLarry is offline   Reply With Quote
