![]() Join Date: Sep 2009
Re: HEI Problem
the wire to the disturb tor needs to be I think 14 gaqe or bigger. if it was not changed and used the original wire it would not bring enough juice to the distributor.
Re: HEI Problem
I bought wires for the dist. today. They have the connectors on the ends that go into the dist. One for volts, and one for the tach. The volt wire is 12 gauge. I got them at NAPA. When I run the new wire to it should I put in a inline fuse? And, if so what amp?
