02-15-2014, 12:29 PM | #1 |
cheapie ebay oil catch cans
I keep reading about how these motors ingest oil through the PCV into the intake
anyone running one of these cheap ebay catch cans? http://www.ebay.com/itm/BLACK-ALUMIN...-/161082361769 I had a fancy $$$ one some years back on a big block, and it seemed exactly like this thing IIRC also open to better ideas. |
02-15-2014, 12:57 PM | #2 |
Freakin Awesome!
Re: cheapie ebay oil catch cans
This is the one I used on my '06 GTO...
http://www.eliteengineeringusa.com/e...ing-catch-can/ A bit pricey but it is well made and looks stock.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee |
02-15-2014, 01:26 PM | #3 |
meowMEOWmeowMEOW
Yikes. thats $160 for the same thing as a sprite bottle with some holes punched in it....
The only thing about really cheap ones is that the fittings usually aren't the highest quality, and the "level" tube on the side sometimes can leak. Usually you can find a million of these under different sellers, and there are a few better ones out there. I had one like that on my SRT4 and aside from a slight weep on the level thing, it worked well. I used one of these, and it was pretty nice.. much better quality than the ebay round ones.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
02-15-2014, 03:00 PM | #4 | |
Freakin Awesome!
It wasn't cheap but I was able to put it in an forget it other than when I checked the oil. It also looked stock so I didn't have to worry about the CA smog Nazi's failing me on visual.
02-15-2014, 03:53 PM | #5 |
Can someone show how this is plumed into the motor. Thanks
02-15-2014, 06:05 PM | #6 |
came across this one on an LS1tech search, looks aight
http://www.ebay.com/itm/BLEMISHED-Po...item3a8b787df2 how are you guys plumbing these on truck style intakes? to the TB pcv port and to the valve covers? |
02-15-2014, 07:11 PM | #7 | |
Freakin Awesome!
02-16-2014, 12:27 AM | #8 |
like direct to the plenum?
shouldnt matter because the MAF is upstream of all that so "total" air is all measured already uh,did that make any sense at all? like i said. very new to these motors. |
