New invention to fill my '73...no more spilling
So I was thinking about this for a while and finally fab'd it up today. Bought a metal gas cap from the auto store along with a metal funnel. Drilled out the middle and inserted the funnel. I couldnt weld it because the metal is thin so I used plumbers solder and a torch. I keep it in a plastic tub in the bed.
Works awesome. What do you think?
1973 Chevy K20 |
Re: New invention to fill my '73...no more spilling
Pic with it attached
1973 Chevy K20 |
Close up
1973 Chevy K20 |
nice, you are gonna want to seal up the collar around the base of the funnel itself as well, i have one and it leaked like hell until i hit it with a little jb weld
"DON'T TOUCH THE TRIM!!"-Early Kyler |
![]() Join Date: Feb 2011
Thanks for the idea, I'll have to finagle something like this.
MusicMan70 1961 GMC Suburban |
Another Day, Another Dollar
If you just hold the trigger on the nozzle partially down, and dont bury it all the way down the fill hole it won't overflow either
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() |
That doesn't really work with California nozzles. Unless you go extremely slow it will overflow.
1973 Chevy K20 |
OMG those new fangled gas hoses. Now I see where you're coming from and that looks like a good work around to me. Cheers.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
It mainly for the CA hoses with the plastic foreskin
1973 Chevy K20 |
I hope they don't get those up here though it seems Cali sets the precedent for all that sort of crap
good timing with this. Dropping my truck off this week to start paint. Also looking to modify refuel area so I dont spill anymore here in Cali. Since this wont exactly work here, what else you guys doing?
Looks good i need to build something like that the step side is a pain to fill
I figured a step side might be easier.
1973 Chevy K20 |
I'm curious to see what these gas nozzles look like. Someone should snap a pic the next time they're filling up...
Austin 1996 Chevrolet K1500 Silverado ![]() 1979 Chevrolet K10 Scottsdale - Carolina K10 - My 4.8L Twin turbo build - Project Short Stroke - Instagram - TheBlueBomber1996 |
#15 |
Here you go. You have to pull back that rubber foreskin and the nozzle only fits part way into the tank.
1973 Chevy K20 |
#16 |
Lol I understand completely now. That's ridiculous.
#17 |
Carry a screwdriver and take it off (since only a worm clamp holds it on) each time you fill up :P
Trevor 74 C20...work in progress. 04 Saturn Ion...Daily Driver |
#18 |
JD,
Interesting you post a picture of the gas pump next to a VW bus.. I have been fighting this problem in Dallas, Texas with my 77 VW Bus and now I have a 78 C10 that is causing the same issues. MY FIX: I have a small power screwdriver. I quickly remove the rubber vapor hose on the gas nozzle (usually only one nut on the hose clamp) and replace when I am done. Hopefully in the future I will forget to replace the vapor hose and will make regular appearances at that particular pump. |
#19 | |
But I woudl be worried about getting a nice fat fine from the great state of California for something like that.
1973 Chevy K20 |
#20 |
In the Forgotten far North.
![]() Join Date: Jul 2007
nah not for me either. I'd just whip out my utility knife and circumcize them hoses like I was a moyl(sp?)
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
#21 |
For the past few years ive always wondered what was with the issue everyone was having when filling up as I never experienced a problem...fast forward to last week. Go to fill up, set the pump and as im looking my truck over I notice a puddle forming under my nozzle. I found setting the pump slower and turning the nozzle at a 45 degree angle helped. However if I had nice paint your invention would be something id definitely fab up.
