Old 01-16-2014, 01:04 PM   #1
jamesjones
Freakin Awesome!
jamesjones's Avatar
Thorley LS Swap Headers Q
Is anybody who has these able to give the dimensions of the headers? I'm looking for some headers for my swap but space is super tight. The engine in my '72 blazer was orginally mounted in the rear most location and I have some custom made engine mounts. I'd like to have a decent idea about them fitting before I drop the coin on them.
I'll snap some pics when I get home to give an idea of the space I'm working with.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 01-16-2014, 02:03 PM   #2
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Re: Thorley LS Swap Headers Q
So your engine is still in the rear mount location or its moved forward?
chevyguy_72 is offline   Reply With Quote
Old 01-16-2014, 02:54 PM   #3
jamesjones
Freakin Awesome!
jamesjones's Avatar
It's still in the rear mount position. I meant I say the old engine was mounted in that position so the new mounts are based on that position.
Old 01-16-2014, 02:57 PM   #4
chevyguy_72
Vintage Evil
ok... mine is mounted in the rear holes now... and the DT headers fit fine... but you also have to consider the perches and mounts you are using... i currently have CPP sheetmetal perches with dirty dingo slider mounts...
as seen here:
http://67-72chevytrucks.com/vboard/s...8&postcount=14
Old 01-16-2014, 08:12 PM   #5
jamesjones
Freakin Awesome!
jamesjones's Avatar
Here's pics of the space I have on the driver's side...
Old 01-16-2014, 08:14 PM   #6
jamesjones
Freakin Awesome!
jamesjones's Avatar
Here's the space I have on the passenger's side...
Old 01-16-2014, 09:06 PM   #7
truckdude239
truckdude239's Avatar
Trailblazer ss manifolds eould probely clear
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 01-17-2014, 08:43 PM   #8
jamesjones
Freakin Awesome!
jamesjones's Avatar
Yeah, after taking a closer look at those manifolds and the space I have to work with, I honestly think that's my best option. I'm gong to order a set and if they work, I'll just get them ceramic coated and call it a day.
Old 01-17-2014, 09:12 PM   #9
truckdude239
I used them on my 71 clered great and i coukd use the stock downpipes. Also i only had 140 buxs in manifolds instead of 700 for swap headers
David fuller
2000 Tahoe 5.3l 378
Old 01-18-2014, 11:31 AM   #10
Hart_Rod
Hart_Rod's Avatar
2010+ Camaro manifolds shoul work.
Hart_Rod is offline   Reply With Quote
Old 01-18-2014, 02:03 PM   #11
jamesjones
Freakin Awesome!
jamesjones's Avatar
Do those flow better than the TBSS manifolds?
Old 01-18-2014, 02:37 PM   #12
Hart_Rod
Hart_Rod's Avatar
There are some pictures in my shifted thread.
Old 02-09-2014, 11:27 PM   #13
jamesjones
Freakin Awesome!
jamesjones's Avatar
Well, I decided it wasn't worth the $600 risk for the DTs to not fit and bought a set of 2010 Camaro manifolds off of ebay.
Old 02-09-2014, 11:45 PM   #14
66LSx
66LSx's Avatar
FOR OTHER MEMBERS WHO SEARCH UPON THIS
You need to check to see WHAT DT header you are using..
322 (60-66) and 323 (67-72) headers exit with a downward angle towards the ground.
These are both 1-7/8 primaries
324 exits straight out... slightly longer... and is only 1-5/8" primaries.
I have Doug Throley 324 headers in my 66 (although there made fora 67-72)
Differences between LS swap c-10 headers
322 & 323
They fit with alot of room in my 1966 c10... you should have all the room in the world for your 67-72..even at the firewall... but your REALLY far back there...
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 02-10-2014, 12:06 AM   #15
jamesjones
Freakin Awesome!
jamesjones's Avatar
Yeah, the more I looked at pictures of them installed and compared them to the placement of my engine, I just don't see them fitting, I think the Camaro manifolds are going to be a tight fit. I just want to get it up and running and then I'll have some custom headers made down the line.
Old 02-10-2014, 12:10 AM   #16
66LSx
66LSx's Avatar
The more and more I look at your picture..... the more I think cylinder #6 would hit.... this is the passenger side tube that goes up and over #8... i think it would come down and smack the lower corner of the doghouse.
1966 C10 SWB Fleet
Old 02-10-2014, 03:57 AM   #17
akdg87
akdg87's Avatar
I did an install on a 70 k10(with motor slid back as far as possible) and the issue I ran into with the Doug Thorleys was the o2 sensor bung placement on the passenger side. It was angled at the frame rail and there was no way possible to install it.
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 02-17-2014, 09:51 PM   #18
jamesjones
Freakin Awesome!
jamesjones's Avatar
Here's the 2010 Camaro manifolds for those interested...
Old 02-17-2014, 09:53 PM   #19
jamesjones
Freakin Awesome!
jamesjones's Avatar
Here's the fitment on the passenger's side...
Old 02-17-2014, 09:57 PM   #20
jamesjones
Freakin Awesome!
jamesjones's Avatar
Here's the fitment on the driver's side...
I'm going to need to take a sledge hammer to the firewall to make room for the last header bolt...
