Old 02-18-2014, 03:45 AM   #1
Rich 5150 69
Rich 5150 69's Avatar
Re: HEI Problem
Originally Posted by pdxhall View Post
If the truck was running fine and now it's not why would the wiring hook up be wrong. It has to be something that has failed or come loose. Pull a plug wire and check for spark first.
GRS original post said it was coming from the firewall plug, ( resistor wire....?, only getting 7 volts ) he needs direct from the ignition pink wire. Plus those plugs have always been a source of failure with resistance and corrosion.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 02-18-2014, 12:14 PM   #2
grs
Re: HEI Problem
When I crank the truck to start it. I get 7 t0 8 volts to the hei. When it is in run position with the key on it is 12 volts. I have replaced the module, cap, and rotor. I may just go ahead and replace the coil too before trying to start it. And I am going to run a 12 gauge wire from ing. switch , or fuse to the hei.
grs is offline   Reply With Quote
