02-18-2014, 04:25 AM | #1 |
Gauge cluster electrical problems
Has anyone had this problem before?
Dolphin Gauges all work fine with headlights off. As soon as I turn headlights on all gauges stop working (go to zero or max). Is there a short or is it improperly grounded? Truck is at the shop otherwise I'd take a video for a better reference. Here's a pic of the setup. Not sure what PO did with wiring. |
02-18-2014, 06:19 AM | #2 |
It's alsways something.....
Re: Gauge cluster electrical problems
ground ground ground ground
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
02-18-2014, 06:41 AM | #3 |
Cluster King
I could not agree more. The first thing to do is make sure everything is grounded correctly. If ground is not your issue then more information will be needed to help you.
Good luck, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
02-18-2014, 08:54 AM | #4 |
Old member
I have the speed hut gauges in my truck. They work fine also with no lights. When the parking are headlights are on they max everything out but the voltage reading it stays the same. I figure it's a ground, but where? The orignal cluster didn't do this.
My gauges are plastic with a hot wire and a ground.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-18-2014, 01:15 PM | #5 |
Thanks. I'll try re-grounding it and let u guys know if that helps.
